Which method is best?
Postby pieman » Tue Sep 27, 2016 4:58 pm
I have a Global Invacom Quattro which receives signal from a Fibre Optic LNB (Which is great by the way as I receive 99% signal strength!) and distributes this further to two GI 16 way expander's. This gives me 32 ordinary feeds + 4 feeds of each polarity (VL/HL/VH/HH) and the abliity to add more expanders to create more feeds if required.
http://www.gionlineshop.co.uk/Downloads ... -%2002.pdf - GI Quad
http://www.gionlineshop.co.uk/Downloads ... -%2002.pdf - GI Expander
I can either wire up the TBS6909 with ordinary 4 x standard satellite feeds OR I can feed in each polarity.
I wonder if their is any technical advantage to doing it one way or the other?
pieman
Re: Which method is best?
Postby steven » Mon Oct 10, 2016 3:41 pm
Hi pieman
both way should be ok ,depends on you ,you can choose one you want : )
Kind regards
