Installing both TBS6281 & TBS6281SE cards on same machine
Postby BrianS » Sat Sep 24, 2016 6:01 pm
I have been using a TBS6281 card for some months with no problems. I am now looking to add another T2 card and looked at the 6281SE. I have downloaded the latest drivers for each card and noticed that some of the file names are the same, as detailed below. Some of content of the .inf files would also appear to be the same and therefore may cause a conflict.
Will I have any problems installing both cards on the same machine, running Windows 10 Pro? If so, what can I do to get them to install and work correctly?
tbs6281-t2-t-driver_v1.0.0.7.zip
____TBS_6281_driver_setup.exe v1.0.0.7
____tbs-6281_x64
________dpinst64.exe v2.1.0.0
________TBS6281.inf
________tbs6281_64.cat
________tbs6281_64.sys v1.0.0.7
____tbs-6281_x86
________dpinst.exe v2.1.0.0
________TBS6281.inf
________tbs6281.cat
________tbs6281.sys v1.0.0.7
tbs6281se-t2-t-driver_v1.0.0.2.zip
____TBS_6281_driver_setup.exe v1.0.0.2
____tbs-6281_x64
________TBS6281.inf
________tbs6281.cat
________tbs6281.sys v1.0.0.2
____tbs-6281_x86
________TBS6281.inf
________tbs6281.cat
Any comments welcome.
BrianS
Re: Installing both TBS6281 & TBS6281SE cards on same machin
Postby steven » Tue Oct 11, 2016 3:13 pm
Hi BrianS
Thanks for this information.
We already update the 6281se driver please have a check .
Return to PCIe DVB-T2/T/C Dual Tuner Card TBS6281SE
