TBS Linux Driver is updated to v160919.
Postby Jenny » Fri Sep 23, 2016 10:11 am
Dear All,
Here comes a breaking news for your guys: TBS Linux Driver is updated to v160919, which has fixed kernel 4.7 compile error :)
Click here and download the newest TBS Linux Driver: http://www.tbsiptv.com/download/common/tbs-linux-drivers_v160919.zip
Any feedback would be much appreciated. We would like to hear your voice and make first-class digital TV tuner cards / USB box, live IPTV streaming solutions, HD / SD videos over IP Servers solutions such as HDMI / SDI h.264 encoder, IP Video h.265 decoder for you! :P
Best Regards,
Jenny
TBS Technology
Jenny
Re: TBS Linux Driver is updated to v160919.
Postby lordlucan » Thu Mar 02, 2017 2:13 am
Thanks Jenny,
However it doesn't compile under ubuntu 16.04.2 4.4.0-64 x86_64
make [3]: *** No rule to make target '/home/test/linux-tbs-drivers/v4l/tbsctrl.o' needed by /home/test/linux-tbs-drivers/v4l/saa716x_tbs-dvb.o' . Stop
The TBS-5990 download driver is only for TBS-5980 and also is broken.
Is there a working combination of linux and these drivers? Sadly I cannot use the better opensource drivers since the community hasn't added 5990.
I heard that the TBS 2900 Matrix PC is the only device known to work with this adapter. Is this true?
lordlucan
Postby steven » Thu Mar 02, 2017 5:48 pm
Which driver you are using ? please have a try with this one :
#wget http://www.tbsdtv.com/download/document/linux/media_build-0119.tar.bz2
#tar jxvf media_build-0119.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby lordlucan » Sun Mar 05, 2017 12:34 am
Thanks Peter,
I had downloaded the drivers v160919 mentioned earlier in this thread. Anyway the updated link you provided worked fine. You should make this the default download on the website.
Cheers
Craig
lordlucan
Postby lordlucan » Sun Mar 05, 2017 7:36 pm
In case anyone finds this thread, the updated drivers also work with Raspberry Pi 2/3!
hope this helps.
lordlucan
