MOI Pro AMD living in USA help
Postby palenet » Sat Sep 10, 2016 12:31 am
hello
just bought the MOI Pro AMD. Card 6704, need help to get
it pick up OTA local tv stations. I guess cannot get the right frequency.
If you have been successful in getting it to work, I need help
thanks
palenet
Re: MOI Pro AMD living in USA help
Postby qz3fwd » Mon Nov 21, 2016 4:12 am
I have AMD + 6704 and it works fine. TVH is not the most user friendly nor well laid out program but I was able to find my way.
Take care you are connecting the coax cable to the correct connector on the 6704 card. There are 2 F connectors. 1 is the input signal, and the other is pass through. If you connect to the pass through connector you will not get anything. The card as I recall is not labeled well, nor did I receive any information with the unit/cards, and I didn't see anything on their website.
Good luck. The AMD is NOISY!
qz3fwd
Return to MOI Pro - AMD
