Problem with windows driver tbs6522
Postby mounir39 » Thu Sep 01, 2016 6:09 am
Hi guys;
I have just today received my new tbs6522
I download the windows driver from this link http://www.tbsiptv.com/index.php?route= ... vers&id=29
last version
l have windows 7 on my PC
When i installed the driver i get this message
< Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)>
and the card has a yellow icon on the device manager window
is there a solution ?
mounir39
Re: Problem with windows driver tbs6522
Postby Peon » Sun Oct 16, 2016 5:00 pm
mounir39 Wrote:Hi guys;
last version
It is necessary to allow the driver installation, despite the warning. Do not be afraid, nothing will go wrong. Here is the latest driver http://www.tbsiptv.com/download/tbs6522 ... .0.0.3.zip
Peon
Postby Magwitch » Tue Oct 18, 2016 11:31 pm
I have the same problem as mounir39. The driver does not install correctly, after trying several times. I have the yellow warning sign against the driver in device manager. The Driver status says it cannot verify the digital signature etc. etc.
I uninstalled the TBS6983, but still have the problem. What to do?
Windows 7 x64.
Magwitch
Postby steven » Wed Oct 19, 2016 4:03 pm
Hi all
For code 52 issue please have a check this :
viewtopic.php?f=86&t=9989
it will fix your problem
Postby Magwitch » Wed Oct 19, 2016 5:55 pm
Thanks for the link. That update is already on my PC, but marked as failed. I need to somehow find a way reinstall it.
Rgds Magwitch.
Magwitch
Postby steven » Mon Oct 24, 2016 11:22 am
Hi Magwitch
The update need windows 7 SP1 ,check your system whether is SP1
Postby Magwitch » Tue Oct 25, 2016 7:48 pm
OK now with fresh Windows OS install. Thanks.
Magwitch
