New TVHeadend *UNSTABLE* version: 4.1-2211
Postby costan » Tue Aug 30, 2016 9:58 pm
the last TVH *UNSTABLE* version.
I did not have the chance to test it on my box, ATM I don't have it available.
NEW VERSION: 4.1-2211
Instruction almost the same as the other thread viewtopic.php?f=164&t=9352 (just replace -new with -4.1).
Pointer:
http://www.costan.org/moiplus/README-4.1.txt
Indeed I had no chance to test it, so use at YOUR OWN RISK.
Let me know if it works, anyway :)
costan
Re: New TVHeadend *UNSTABLE* version: 4.1-2211
Postby ivx675 » Fri Sep 02, 2016 2:20 am
Thanks,
Currently it's already more stable than 4.0.9, currently no restarts needed ...
I will update post with longer running result.
ivx675
Postby jtrefil » Fri Sep 23, 2016 2:07 am
Thanks for a job well done. :)
A week back I made the update to 4.1-2211 and still works perfectly.
There was no need to restart and looks reliable.
The previous version was 4.0.8, I often had to restart, can not identify what it was,
but stopped communicating by decoding through OSCAM.
OSCAM is a chapter in itself. Sometimes it does not load the access card reader via USB SmartReader V2,
the log displays the error card, but after several restarts will catch, but this is not a problem here.
jtrefil
Postby costan » Wed Oct 19, 2016 8:08 pm
jtrefil Wrote:Thanks for a job well done. :)
I've also an OSCam recente binary compiled by myself.
I'll put in the web host and create a topic for the OSCam installation.
costan
Postby jtrefil » Wed Oct 19, 2016 9:32 pm
This is great news, thank you for that. :) :) :)
jtrefil
Postby ivx675 » Fri Oct 21, 2016 7:54 pm
Can you add pcscdevice (normal smart card reader) suppoort for oscam ?
Currently running oscam on windows computer, because i'm too dumb to install pcsc support for MOI+ ....
This version TVHeadend work without problems since you released it.
Only problem i have is that 760mhz MUX channels will switch at least 15sec, i suspect that is DVB-T drivers related ...
ivx675
Postby costan » Wed Oct 26, 2016 6:01 pm
The OSCam binary:
http://www.costan.org/moiplus/oscam-svn11272
This also have the EMU inside, the Softcam.key file should be in the same path as oscam.conf (/usr/local/etc).
About the smartcard reader support, I think I need to prepare also the libraries for MOI+ before compiling OSCam.
Just try this one and let me know if this works (besides of the smartcard reader).
EDIT: Corrected link to right version
costan
Postby jtrefil » Wed Oct 26, 2016 10:28 pm
The OSCam binary:
http://www.costan.org/moiplus/oscam-svn11273
Super, thanks a lot ..
I understood correctly, that is enough to rename the "oscam" and replace the original in /usr/local/bin?
After running pops up an error:
FATAL: kernel too old
Segmentation fault
Here in the forum I found the oscam ver.9813, which I use for test. Launched without problems.
So I hope that I understand how to use properly.
I'm sorry but you do not have the experience of compilations, if need be.
Please advice about where to begin.
Thank you.
jtrefil
Postby costan » Wed Oct 26, 2016 10:40 pm
Ops.. sorry my bad. I gave you another oscam (same CPU type, different subversion and kernel) for another ARM box I have (not TBS, and Android based).
Please use this link:
costan
Postby jtrefil » Wed Oct 26, 2016 10:54 pm
costan Wrote:Ops.. sorry my bad. I gave you another oscam (same CPU type, different subversion and kernel) for another ARM box I have (not TBS, and Android based).
Thank you, now works wonderfully. :D :D :D
jtrefil
Return to MOI+
Users browsing this forum: Bing [Bot] and 0 guests
