TBS6205 not detected by Tvheadend
Postby stevie » Thu Aug 11, 2016 3:07 am
My Moi Pro is running v1.0.0.11 with Tvheadend 4.14.1.
Initially I had a TBS6281 dual terrestrial card installed with no issues. However I recently upgraded to a TBS6205 quad card and removed the TBS6281.
The frond display now strangely shows 8 receivers, 0 to 7, /dev/dvb lists 4 receivers adapter0 to adapter3 and in Tvheadend under TV Adapters no adapters are displayed.
I've gone through the entire forum under Moi Pro but cannot find a similar issue reported.
I'd appreciate any assistance as this card is listed as supported and I was hoping to add a TBS6904 to work along side it at a later date.
stevie
Re: TBS6205 not detected by Tvheadend
Postby steven » Thu Aug 11, 2016 11:34 am
It is tvheadend issue please have a try delete the tvheadend config folder and try again
rm -rf /.hts/tvheadend/
rm -rf /root/.hts/tvheadend/
Kind regards
Postby stevie » Fri Aug 12, 2016 1:33 am
steven Wrote:It is tvheadend issue please have a try delete the tvheadend config folder and try again
I tried the above, rebooted and the front display still shows 8 adapters, /dev/dvb shows 4 adapters and tvheadend still displays no adapters.
stevie
Postby stevie » Mon Feb 06, 2017 10:24 pm
In case anyone else comes across a similar issue I resolved the problem by doing a full OTG usb cable firmware update to v1.0.0.11.
I had previously updated via the web page option which is a smaller file and does not appear to contain all the necessary drivers for the supported TV cards.
stevie
Return to MOI Pro
