Any news on drivers for Linux Kernel 4.x?
Postby alien878 » Fri Aug 05, 2016 2:56 pm
Mythbuntu is moving to Linux Kernel 4.x. Any news on whether the Linux drivers will work with 4.x? The latest version only has setup scripts for 2.x and 3.x.
Thanks,
Allen
alien878
Re: Any news on drivers for Linux Kernel 4.x?
Postby steven » Tue Aug 09, 2016 11:19 am
Hi Allen
We are on working the open source code driver now ,you can check here:
viewtopic.php?f=86&t=9960
but for 8922 have not added yet ,we will try to add it in next update.
Postby crazycat » Wed Aug 10, 2016 3:12 am
alien878 Wrote:Mythbuntu is moving to Linux Kernel 4.x. Any news on whether the Linux drivers will work with 4.x? The latest version only has setup scripts for 2.x and 3.x.
Current drivers support up to 4.6 kernel. Use config script for 3.x ( anyway for x86_64 same script for all kernel versions).
Postby alien878 » Tue Aug 23, 2016 4:58 pm
Thanks steven/crazycat.
I'm still on 32bit. Originally because of some driver issues. They've probably been fixed a long time now, but changing to 64bit looks like it requires a re-install for almost no gain.
Anyway, at least I know I have two potential options. Once the mythbuntu 16.04 upgrade stabilizes, I'll give it a try.
Thanks again,
Allen
alien878
Postby alien878 » Tue Feb 28, 2017 8:19 pm
Just a quick update. I tried both drivers and both work fine on 4.x. I'm currently using the open source drivers as they are a bit easier to build.
alien878
