ubuntu kernel 4.4 can not install the open source driver
Questions on running streaming box on your windows
Postby steven » Wed Apr 03, 2019 9:11 am
Hi All
If you can not install the open source driver please try like this :
We find that sometimes when using ubuntu kernel 4.4.0 can not install the driver , compile and install both are ok
but there is no dvb device in this case please update the kernel to 4.16 then try again
update the kernel you can do like this :
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.16/linux-headers-4.16.0-041600_4.16.0-041600.201804012230_all.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.16/linux-headers-4.16.0-041600-generic_4.16.0-041600.201804012230_amd64.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.16/linux-image-4.16.0-041600-generic_4.16.0-041600.201804012230_amd64.deb
sudo dpkg -i *.deb
reboot
after reboot using
uname -a check the kernel weather is 4.16 is yes then start install like this :
#wget http://www.tbsdtv.com/download/document/linux/media_build-2019-0308.tar.bz2
#tar jxvf media_build-2019-0308.tar.bz2
#cd media_build
#./install.sh
#reboot
Re: ubuntu kernel 4.4 can not install the open source driver
Postby crazycat » Sat Apr 06, 2019 10:00 pm
Problem caused kernel headers update after 4.4.168+ (ubuntu 4.4.0-142+ kernels)
I make temporary fix for backport patch in separate fixes branch https://github.com/tbsdtv/media_build/tree/fixes
Similar fix for old linux-dvb-drivers, if someone use it
https://bitbucket.org/CrazyCat/linux-tb ... c57ede115b
Postby steven » Fri Apr 12, 2019 5:03 pm
hi crazycat
Thanks so much for your update
Postby johnnysamu » Fri Dec 29, 2023 2:32 am
Linux moipro-amd 6.2.0-39-generic #40~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Thu Nov 16 10:53:04 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
I have a newer kernel and don't want to change it. I don't get a TV adapter. I have tried every idea I can find on the internet. This problem occurred after I switched to Ubuntu server 22.04
It was working fine before I messed up, during a backup.
I have two tv cards, nothing is found by tvheadend
I have used all Steven tricks.
/Johnny
johnnysamu
Postby johnnysamu » Sun Dec 31, 2023 12:11 am
I solved the problem of orderly installation in ubuntu 22.04 with
sudo apt-get install patchutils
johnnysamu
Return to Windows Client end help
