TVheadend with support of Constant Control Word
Postby gfi » Sat May 25, 2013 8:59 pm
Only for test (version 3.5.xxxx), for users what already have access code (Control word) from provider.
Bundle type (all webui images, scripts are included in binary), You just need only create directory for handle and save configs.
For test (place file 'tvhccw' in /tmp folder).
Over SSH type:
cd /tmp
mkdir tvhroot
./tvhccw -C -c /tmp/tvhroot
You can find section of CCW in CSA category.
Fill values by services category.
Note: If You got a 6 Byte code from provider, You need calculate it for a 8 Bytes Control Word.
It's a standard csa (CSA use 6 Byte encryption system, DES - 7B) checksum.
This calculation is public and used as public information.
Thats mean:
4B = 1B + 2B + 3B and 0xff
8B = 4B + 5B + 6B and 0xff
(and = logical operator)
tvhccw.part2.rar
(1003.42 KiB) Downloaded 559 times
tvhccw.part1.rar
(1 MiB) Downloaded 538 times
gfi
Re: TVheadend with support of Constant Control Word
Postby bimse » Thu Nov 28, 2013 7:40 pm
"The selected attachment does not exist anymore."
Please could you fix that. Thanks
bimse
Postby tbs6925 » Mon Sep 29, 2014 11:33 pm
please fix the link
tbs6925
Return to Streaming box development
