TBS tuner USB
TBS tuner USB
Postby Delta1Star » Sat Mar 18, 2023 4:55 pm
Hallo Members.
At a certain point you can no longer see the wood for the trees, because of all the information that comes your way.
I'm looking for a TBS USB (box) that can handle everything or almost everything.
Mvg
Delta1Star
Re: TBS tuner USB
Postby EnoSat » Sat Mar 18, 2023 6:00 pm
TBS5590 ?
EnoSat
Re: TBS tuner USB
Postby Delta1Star » Sat Mar 18, 2023 7:17 pm
Now i have the TBS 5927 and still happy with it ,but i wonne recief more in other bands.
Mvg
Delta1Star
Re: TBS tuner USB
Postby Delta1Star » Sun Mar 26, 2023 4:39 pm
Members, I am dubbing what or which one I will buy in terms of a USB box.with or without C and or T.but it must have S2X on it
Delta1Star
Re: TBS tuner USB
Postby Delta1Star » Tue Mar 28, 2023 2:05 am
which of you is using the 5530.
Delta1Star
Re: TBS tuner USB
Postby smile » Tue Apr 04, 2023 10:49 am
Hi sir
if you just want to use the s2x, you can try the 5930.
Best Regards
smile
Re: TBS tuner USB
Postby Delta1Star » Thu Apr 06, 2023 12:26 am
Can I also get S2X signals with my TBS5927 via another program !?!
Mvg
Delta1Star
Re: TBS tuner USB
Postby DVB » Thu Apr 06, 2023 10:28 am
No. 5927 has got no S2X hardware support, this cannot be overcomed by software.
For 5930 be aware that blindscan is basically non-existant on this device, latest tests were: viewtopic.php?f=233&t=25633&p=56923&hilit=5930#p56906 (RFScan support only, Blindscan fires up, but takes ages to complete and finds nearly nothing) and for 5530 blindscan status is yet under verification, because it was just added a few days ago to StreamReaderEx-BDA by crazycat. Device is very promising, but not much users yet have got it.
And now you're watching 8K:
KKKKKKKK
DVB
Re: TBS tuner USB
Postby Delta1Star » Thu Apr 06, 2023 10:50 pm
I don't know which one I will buy.
I have obtained information from TBS technology, and they are talking about: ACM, VCM?!
Best regards
Delta1Star
Return to Off topics
