Midnight Commander [Linux package]
Postby gfi » Sat May 04, 2013 12:15 pm
Adjusted mc for direct editation of Your config files (mumudvb, dvblast, etc.) over SSH.
Wiki:
http://en.wikipedia.org/wiki/Midnight_Commander
Note: Tou need to have installed an opkg manager (viewtopic.php?f=95&t=8485)
1.
Over ssh type:
opkg install mc-moi.ipk
2.
You can control installation with:
opkg list
3.
type:
mc
Note: installed all locales, but will be upgraded to en language only as soon. Included editation scripts, missing elfviewer, meanwhile.
You can remove package with command:
opkg remove Moi-package-mc
For newbies and weekly users:
Be careful, don't change any rootfs files, You can create/change/edit files only in /tmp folder. With careless using You can damage filesystem in MOI !!!
mc-moi.part2.rar
(622 KiB) Downloaded 981 times
mc-moi.part1.rar
(1 MiB) Downloaded 1046 times
gfi
Re: Midnight Commander [Linux package]
Postby TUISTERa » Tue Jul 09, 2013 9:39 pm
Attachments are gone...
TUISTERa
Postby gfi » Wed Jul 10, 2013 12:54 pm
TUISTERa Wrote:Attachments are gone...
Try now...
All attachments will be re-uploaded this week (+some another tools).
gfi
Return to Software
