Update Question: How can i enter uboot quickly ???
Postby ProTechEx » Sat Jan 04, 2014 5:11 am
i want update my MOI Box Firmware from the Version 1.0 to Firmware_V2.0.2
2. from V1.x to V2.0.2
1) Connect RS232 serial cable & install software.
Connect one end of the RS232 cable to MOI, the other end to your PC, install the software:
- for Windows users: TTERMPRO
- for Linux users: minicom
2) Update through micro SD card*
Prepare a formatted micro SD card, copy the file “MOI290-fs.bin” into it, insert it into the SD card slot on MOI, power on MOI, "Enter" uboot quickly (within about 3 seconds after MOI is powered on) and input the command lines:
setenv loadmmcfs 'fatload mmc 0:1 40000000 MOI2900_fs.bin'
setenv updatekfs 'nand erase 50c0000;nand write.yaffs 40000000 50c0000 ${filesize}'
save
then input "re", MOI will start to update.
I want Update through micro SD card, bu I doesn't understand this Part:
How does i can enter uboot quickly ???
ProTechEx
Re: Update Question: How can i enter uboot quickly ???
Postby steven » Sat Jan 11, 2014 8:13 pm
Hi ProTechEx
This just mean ,when you power on MOI,it will stay in u-boot for 3 seconds,press any key in the RS232 console application to stop it enter
kernel. :)
Postby celevra » Sun Jan 12, 2014 7:02 pm
where do i get the rs232 adapter from?
best regards
celevra
Postby wankel » Tue Jan 14, 2014 9:20 pm
Steven,
Do you have such a cable? Or are there maybe several versions of the MOI?
Mine does not have a standard serial connector, but a 4-pin outlet that looks like the power socket of a floppy disk. I have been unable to either find (links to) the correct cable/convertor, the type of socket on the MOI or the labels for the four pins.
I hope you can help out, reading the forums there must be scores of people who actually are able to hook up their MOI to a serial port, but I have the faintest idea how the make it.
Best regards!
wankel
Postby zfm2700 » Wed Jul 16, 2014 5:54 pm
Bump. I also have the weird molex-style connector labeled RS-232. You can see it in the pictures of the MOI on the TBS website. I cannot figure out the exact identity of this connector nor the pinout. Does everyone who successfully uses the serial have a DB9 connector on their MOI instead? What about the rest of us? :?
zfm2700
Return to Install and setup
