My version number on the setup page is shown as 1.2:
The latest version of the firmware is apparently 1.2.1 so I presume I should be updating but as you can see above the update page does not tell you which files to select and the files I have downloaded are below, the readme file doesn't even explain which files you should choose, it's not very helpful to be honest.
Could someone confirm which files to choose for both options? Should I be choosing MOI2900_k.bin for the kernel and MOI2900_fs.bin for the rootfs? If so, why isn't this explained in the readme? That's what a readme is supposed to be for. Also what are the rest of the files for?
Many Thanks
