[SOLVED] Configuration - Accesscontrol
Postby marcelp1 » Tue May 07, 2013 5:54 am
I have try to add a user to password protect the GUI and disabled the default no user name/ password and now cant login :(
Enabled: Tick
Username: moi
Passowrd: moi
Prefix: 0.0.0.0/0,::/0
Streaming: Tick
Video Recorder: Tick
All configs (VR): Tick
Web interface: Tick
Admin: Tick
I have looked in root/.hts/tvheadend/accesscontrol/
"enabled": 1,
"username": "*",
"password": "*",
"comment": "Default access entry",
"prefix": "0.0.0.0/0",
"streaming": 1,
"dvr": 1,
"webui": 1,
"admin": 1,
"id": "1"
but there is no user moi so I can re-check the password :(
How can I get access back to GUI?
marcelp1
Re: Configuration - Accesscontrol
Postby updatelee » Tue May 07, 2013 7:12 am
Just guessing but try adding a user moi in the console
Postby marcelp1 » Tue May 07, 2013 7:20 am
Well I have just re-started the MOI and now there is HTTP authentication to watch any channels ... grrrrrr...
I would rather delete the moi user and enable back the no user/password .....
You mean on the system "sudo adduser moi"?
If so I do not think that would help ... as the tvheadend runs under root on startup i think ...
marcelp1
Postby marcelp1 » Tue May 07, 2013 7:48 am
OK, I have just tried to add new user:
vi /root/.hts/tvheadend/accesscontrol/2
"enabled": 1,
"username": "admin",
"password": "secret",
"comment": "Admin",
"streaming": 1,
"dvr": 1,
"webui": 1,
"admin": 1,
"id": "2"
And rebooted and still no luck :(
Anyone any ideas?
marcelp1
Postby marcelp1 » Tue May 07, 2013 8:02 am
I should have checked
https://tvheadend.org/projects/tvheaden ... figuration
before playing with the users :(
there is no ~/.hts/tvheadend/superuser on my MOI, should it be on it?
marcelp1
Postby cody » Wed May 08, 2013 1:49 am
i answered basically about the same here:
viewtopic.php?f=94&t=8495&p=28900#p28900
Postby gfi » Wed May 08, 2013 6:01 am
marcelp1 Wrote:I should have checked
So, that is partly starting script problem... TVheadend starting as admin superuser, due to default parameter in startup script is -C.
gfi
SOLVED Re: Configuration - Accesscontrol
Postby marcelp1 » Wed May 08, 2013 4:11 pm
I have managed to solve it.
I have TVHeadned running on Raspberry PI as well and got confused that the config files for TVHeadned
will be located in /home or the /root folders AND did not notice /.hts/tvheadend/ :(
# ls -ila
total 34
1 drwxrwxr-x 1 default default 2048 Mar 29 00:13 .
1 drwxrwxr-x 1 default default 2048 Mar 29 00:13 ..
405 drwx------ 1 default default 2048 Mar 28 04:27 .hts ------------ DID NOT SEE IT :( should have gone to specs ...
570 lrwxrwxrwx 1 root root 11 Dec 7 10:46 bak-linuxrc -> bin/busybox
258 drwxr-xr-x 1 root root 2048 Mar 28 20:30 bin
138 drwxrwxrwt 7 root root 2240 May 6 17:43 dev
343 drwxr-xr-x 1 root root 2048 May 6 17:43 etc
448 drwxr-xr-x 1 root root 2048 Mar 13 03:35 home
526 drwxr-xr-x 1 root root 2048 Dec 7 10:46 lib
550 -rwxr-xr-x 1 root root 168 Dec 7 10:46 linuxrc
2 drwx------ 1 root root 2048 May 6 17:43 lost+found
555 drwxr-xr-x 1 root root 2048 Dec 7 10:46 media
338 drwxr-xr-x 1 root root 2048 Jan 4 2000 mnt
556 drwxr-xr-x 1 root root 2048 Dec 7 10:46 opt
1 dr-xr-xr-x 57 root root 0 Dec 31 1969 proc
518 drwxr-xr-x 1 root root 2048 May 4 15:56 root
342 lrwxrwxrwx 1 root root 3 Dec 7 10:46 run -> tmp
3833 drwxr-xr-x 1 root root 2048 Dec 7 10:51 sbin
1 drwxr-xr-x 12 root root 0 May 6 17:43 sys
155 drwxrwxrwt 2 root root 140 May 6 17:43 tmp
571 drwxr-xr-x 1 root root 2048 Dec 7 10:46 usr
558 drwxr-xr-x 1 root root 2048 Dec 7 10:46 var
453 drwxr-xr-x 1 root root 2048 May 4 13:07 www
just edited /.hts/tvheadend/accesscontrol/2 to disable it and enabled
/.hts/tvheadend/accesscontrol/1
marcelp1
Return to Install and setup
