[ Moderator Control Panel ]
by ahmedramze » Tue Feb 11, 2014 9:12 am
Hello
when I view 3 channels I got cpu 100%
- MOICPU3.PNG (9 KiB) Viewed 2382 times
only two can run with low cpu load.
- MOICPU2.PNG (9.52 KiB) Viewed 2382 times
is there is wrong in my config ?
these channels use CCAM client.
Ahmed
ahmedramze
Return to General discussion
