[PRODUCT REVIEW] TBS MOI STREAMER (DVB-S2 Streaming Box)
Postby warumnix » Mon Dec 30, 2013 3:17 pm
NOTE: The review is original a forum thread in xbmchub forum by the forum member Flapster.
As promised my full review of the MOI Streaming Device.
I am in no way affiliated with TBS or the MOI streaming box and this review is an honest and open opinion made from my own findings with the MOI. TBS sent me a box to test so that I could share my findings with the XBMCHUB, after I was cheeky on a Facebook chat with them asking for one to test.
First up i'd like to share my XBMC setup and what the MOI was tested on.
- I'm using a Samsung Smart TV
- Virgin Media SuperHUB with 60mb
- Satellite LNB from an old SKY digital dish setup to receive Freesat. I have 2 LNB connections of which one was used.
- OUYA with Discover Store XBMC, running confluence skin. Manual Fusion install (nothing fancy !!)
- MOI Streaming box sent for testing purposes from TBS.
Overview
The box is a dual DVB-S2 TV tuner and dual CI slot linux server for streaming satellite TV channels to client end devices within your wired or wireless network. Put simply this is a backend server running TVHeadend (amongst others - DVBlast, mumuDVB, szap, scan) which has the capability of streaming live free to air TV around your home for devices that have a front end TVHeadend attached, like XBMC. For me personally I wanted a "do all" box in the OUYA. Although I can simply receive Freesat through my TV I wanted something that could do it all in one box and make me even more lazy, so that I didn't have to change my TV's source to watch Freesat (I know, mega lazy).
From an XBMC point of view and for those of you with a satellite dish, its a way of getting your "LIVE TV" up and running.
For the testing purposes TBS had never tried to run this device with an OUYA. Their website had information on Android devices running it within XBMC, but it look a little bit of a workaround. What I wondered was that, being as the OUYA is a powerful device, would this work as intended within the LIVE TV section of XBMC. I wasn't disappointed !
Whats in the Box
The MOI is very well made. The MOI itself is about the size of a standard router, so not very big. It comes with an RJ45 Network cable, Power adapter (I needed a plug adapter for it as it was a 2 pin plug. Not included). A Quick Start Guide and an RS232 adapter board. I didnt mess with the RS232 as i'm not really that way inclined, but as this is an "open" machine this would be useful for anyone that wants to tinker.
The box itself has 2 tuner ports for your satellite feeds, USB slot, MicroSD slot, LAN, CAM and an RS232 Port. You can find the full specs on their website, but I have to admit, from a Chinese made unit, I very impressed with the build quality and the fact that it seems as no corners were cut in the design and manufacture.
The Setup
OK. Firstly, this is not the MOI's fault, but for me, I haven't had any experience with backend TV servers and satellite feeds, so the learning curve to set the box up was rather large. The MOI software was easy to navigate and was very user friendly. Where I came unstuck was 2 fold.
First, the MOI's IP address is set to 192.168.1.188. My routers IP is 192.168.0.1, so couldn't pick it up when I started it up. Unfortunately Virgin Media are complete massive dicks when it comes to changing IP addresses with the Superhub and I had to mess around with the router as they hide the guest IP. But with a bit of research I managed to change it and change the MOI to my normal IP and change everything back again. Not the MOI's fault, but if you are on Virgin, you will probably know how much a ball ache they make things!!
Secondly, for me anyway, and again nothing to do with the MOI, the lack of online information, even on their website for TVHeadend is poor and for someone like me who has reasonable computer knowledge this was a learning curve and a bit of a trail and error thing. Fortunately the MOI picked up the satellite without me having to do too much satellite tinkering, otherwise I may have lost my mind !!
My one comment for TBS and the manufacturers would be to make a definitive guide for all of the workings for the product. The website and forums for TBS were useful, but not indepth enough. There was one video in spanish which helped, but a multi language guide to TVHeadend, the MOI UI and region specific satellite instructions would have been helpful.
However, I finally hashed my way through the setup and managed to get an abundance of channels loaded. One good thing from my point of view is that I know know more about setting up satellite feeds and backend TV servers. But for me it was a steep learning curve. Lets put it like this. I didn't even know what a MUX was before this. If you are planning to do anything like this I would advise you arm yourselves before hand !
Setting up XBMC with the OUYA for Live TV
Ok this one was very straightforward. I enabled the LIVE TV and TVHeadend frontend, set the IP address in the settings and voila ! The channels were there. It took a while to load as I had quite a few channels. In hindsight I should have setup TVHeadend only with a few channels to test, which I did later on and it loaded alot quicker
Using the MOI on Live TV in the OUYA
This is where the MOI is great. Channels loaded like a charm with EPG. HD worked very well with no lag whatsoever. Channel changing was smooth, although some took a few seconds to load, which I believe happens anyway. I managed to record part of one show which worked fine. The only downside was that I could not for the life of me work out how to get pause to work. I think that this is a TV Headend thing or a "how I set things up thing". Im sure with a bit more playing I would work this out. Along with the OUYA I tested this on my Windows 8 XBMC setup with the exact same results. Overall I was very impressed and quite chuffed that I managed to get things working !!
In the week of my "deepish testing" I had a few crashes. This was mainly when I went to BBC HD, and only BBC HD. This again may have been me or the fact that BBC does all the "red button" stuff, but all other HD channels worked as they should like a charm.
Overall Impressions
The Good - Does what it says on the tin. Streams HD TV around your house. No lag and very powerful streaming.
The Bad - Learning curve. Hard to get your head around the setup if you havent used these types of things before.
The Ugly - None that I can report.
So my overall assessment of this box is very positive. I think this is one of the few times I have seen something that claims to do something that actually delivers. The majority of the problems I had were the fault of third party peripherals. The downside from the manufacturer is that there are no good guides to set up, which may put off potential buyers and weigh down customer service time. I would recommend them to make some indepth user friendly walk through's for novice users.
My rating 4/5 Smiley's (would have been 5 with better guides)
On-going use
If it was not for this forum and TPS, I would not have received this box to test. So, to give something back (it is still Christmas time after all) I am going to offer this box as a giveaway. I will have to check that TPS are ok with this first, but for me, I paid nothing and got to test a genuinely great box. I owe this forum alot and to give a little back I hope that TPS and XBMCHUB will allow me to do this.
As soon as I get the nod from TPS i'll contact the MODs to arrange this.
I hope that this was informative for you all. If you want further information please let me know and I'll be happy to oblige
Flapster.
warumnix
Return to General discussion
