A super PC + TBS tuner (PCIe/ USB), with XBMC/ VDR/ Tvheaded
Postby steven » Tue Dec 03, 2013 4:45 pm
Hi All
TBS is working on a new great product which is Quad core,2GB memory with TBS DVB Tuner Card and Box (DVBS/S2 ,DVBT/T2,DVBC...)support
and XBMC inside. like a super PC. :)
Here is some picture with this product :
TBS5980 with Matrix Box:
and Matrix running VDR as server and XBMC as client with TBS5980 (TVheadend ,mumudvb,dvblast ...all is ok too : ))
TBS6985 with Matric Box:
any advice about this product will be appreciate. : )
more information will be released soon. :D
Return to General discussion
