Dvblast V polarity issue in multicast with tsdecrypt
Postby diabloss » Mon Nov 18, 2013 5:45 am
Hello
Im unable to use more than one channel on vertical polarity via Dvblast from MOI
dvblast cfg
A.cfg
92.87.x.10:1234   1   30908
92.87.x.10:1234   1   30910
92.87.x.10:1234   1   30901
Launching script:
dvblast -a 0 \
-f 12265000 -s 28000000 -v 13 -F 78 \
-c /usr/local/bin/A.cfg -Y \
exit 0
Tsdecrypt :
T10A \
-I 92.87.x.10:1234 -R -z -M 30908 \
-O 239.255.1.1:1234 -r \
-c NAGRA -C 0x0b02 \
-A NEWCAMD -s 127.0.0.1:11110 -U tsdecrypt -P pass -B 0102030405060708091011121314 \
-X 0x15e2 \
exit 0
Please MOISUPPORT help me out with issue.
Thank you
diabloss
Re: Dvblast V polarity issue in multicast with tsdecrypt
Postby ahmedramze » Sun Dec 15, 2013 5:50 am
I have issue on decript using local host IP , I found in this forum you need to setup the lo ip using ifconfig
ifconfig lo 127.0.0.1
every time you reboot , I'm use OSCAM installed in MOI box with Mouse Reader.
ahmedramze
Postby updatelee » Sun Dec 15, 2013 6:28 am
You could put it in one of the init.d scripts so that it does it on bootup
Return to General discussion
