Segmentation fault
Segmentation fault
Postby marcelp1 » Tue Aug 13, 2013 6:28 pm
I have notice while issuing "ip add" command that at the end there was a Segmentation fault
msg.
# ip add
1: lo: <LOOPBACK> mtu 16436 qdisc noop
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast qlen 1000
link/ether 00:22:xx:xx:xx:xx brd ff:ff:ff:ff:ff:ff
inet 192.168.0.1/24 scope global eth0
Segmentation fault
Now is it something I should be worried about?
I know from past, that seeing this kind of msg.
signalled corrupt file system on my Raspberry Pi
but not sure on the MOI.
marcelp1
Return to General discussion
