EPG with xmltv
EPG with xmltv
Postby pixi » Thu Jun 27, 2013 6:13 pm
Is it possible to fix this ??
or can i "feed" tvhedend with a xmltv.xml file ??
or can i maybe use the xmltv.sock for this ??
pixi
Re: EPG with xmltv
Postby pixi » Fri Jul 26, 2013 4:54 am
Any idea about this ???
pixi
Re: EPG with xmltv
Postby gfi » Fri Jul 26, 2013 5:24 pm
This is question for tvheadend support forum, but specially for MOI, need to be installed also xmltv, I think.
Google: tvheadend + xmltv
gfi
Re: EPG with xmltv
Postby gfi » Mon Jul 29, 2013 11:51 pm
pixi Wrote:Is it possible to fix this ??
I think I'll need xmltv too for one provider.
Please, let me know, for what services You need a xmltv (satellite, services).
gfi
Return to General discussion
