dvb options
dvb options
Postby Mechanik » Tue May 28, 2013 1:34 pm
How setup driver options like this:
# DVB Core
options dvb_frontend dvb_shutdown_timeout=1
options dvb_frontend dvb_powerdown_on_sleep=0
at my tbs6984/tbs6985 we use in /etc/motprobe.d/ but this?
Mechanik
Re: dvb options
Postby gfi » Wed May 29, 2013 3:12 am
Mechanik Wrote:How setup driver options like this:
# DVB Core
Drivers are included into kernel (built-in).
You can change default options in sources of dvbcore section in media folder of kernel. But, drivers for MOI tuners are precompiled, only for info.
And of course, compile it.
kernel:
http://www.tbsdtv.com/download/document ... e-code.zip
Please, read instruction how to compile kernel source with patches.
gfi
Re: dvb options
Postby Mechanik » Wed May 29, 2013 3:38 am
this options for dvb_frontend
ok i'll try to change
Mechanik
Re: dvb options
Postby Mechanik » Wed May 29, 2013 10:47 am
ok i build the new kernel with some options
what the next step? How to install new kernel to moi?
Mechanik
Re: dvb options
Postby gfi » Wed May 29, 2013 1:54 pm
Mechanik Wrote:ok i build the new kernel with some options
Rename it to MOI2900_k.bin and place to root of the micro SD card (delete other MOI bin files, if You have).
Control update over RS232 terminal.
Look at readme of firmware update procedure.
gfi
Return to General discussion
