Problem with upgrade via microSD and problem with CAM
Postby jtrefil » Sat Apr 20, 2013 4:04 pm
I have two problems,
AD1 - can not be upgraded via microSD, after reboot no change.
Of course, the poison of your procedure. I have a 2GB microSD card.
You can update manually via SSH? Please advice how to do it.
AD2 - without CAM module MOI find all my channels, but when you insert the CAM does not find anything or even free channels freeze.
In our area we have CAM IRDEO - SKYLINK provider (CSLink).
Please advice.
Thank you and best regards.
Honza
jtrefil
Re: Problem with upgrade via microSD and problem with CAM
Postby gfi » Sat Apr 20, 2013 5:16 pm
jtrefil Wrote:Hello,
Yes, i had a some problem (but I have an 8G card).
1. Connect MOI with PC
2. Stop, when booting.
3. Put:
fdisk -c 0
after procedure control with:
fdisk -p 0
(output must be something like:
partion # size(MB) block start # block count partition_Id
1 6972 1249680 14279880 0x0C
2 126 30480 259080 0x83
3 364 289560 746760 0x83
4 104 1036320 213360 0x83
3. Put:
fatformat mmc 0:1
3. Insert formated card to PC with files for MOI (kernel/rootfs) and copy it to card.
4. Insert card back to MOI
5. Type:
reset
Note: this isn't result of problem.
jtrefil Wrote:AD2 - without CAM module MOI find all my channels, but when you insert the CAM does not find anything or even free channels freeze.
Please advice.
Honza
What type of CAM? (Neotion nCam - some problem)
TVheadend don't working
DVBApps Utils - don't working (scan, etc).
MumuDVB - working with wrong initialisation of CI (Updater), so only fta.
DVBlast - right init, but pixelations when streaming begin, without known reason.
But this CI module need a higher TS Clock and some apps need a bigger DVR Buffer.
And drivers are precompiled...
You'll see, how much is needed for properly using.
gfi
Postby jtrefil » Mon Apr 22, 2013 2:09 am
thank you very much for your answer.
I'm sorry but I do not have much experience, connect to the MOI is meant by RS232 or SSH?
On the RS232 connections need special cable or any regular RS232?
I have two CAM, from TechniSat TechniCrypt CW and from SMIT IRDETA CI +.
The access card SKYLINK IRDETO - freezes with both CAM.
Thank you very much for your help.
Sincerely,
Honza
jtrefil
Postby gfi » Mon Apr 22, 2013 3:44 am
jtrefil Wrote:Hi,
Sincerely,
Honza
Over cross RS232.
About CI module, You have a PM.
gfi
Return to General discussion
