[ Moderator Control Panel ]
by Bipel » Thu Apr 18, 2013 10:27 pm
Is it possible to connect a usb-tuner like tbs5922 to moi?
Bipel
by TUISTERa » Sat Apr 20, 2013 2:52 am
If you have one, you can copy its firmware and test it
Drivers are installed, so it should work with the correct firmware.
TUISTERa
Return to General discussion
