[ Moderator Control Panel ]
by mdx » Wed Apr 10, 2013 4:30 pm
I would like to setup MOI to record to NAS but there seems to be no network filesystem compiled in. Is it possible to add NFS or CIFS (Samba) support to the next release of MOI firmware?
Thanks, Martin
mdx
by mstrzyze » Wed Apr 10, 2013 7:00 pm
+1
but i think you can record from xbmc client to NAS...
mstrzyze
by Giblets » Sat Apr 20, 2013 6:06 pm
I'd like this as well please
Giblets
by marcelp1 » Sat Jun 15, 2013 11:38 pm
+1
marcelp1
by warumnix » Fri Jun 28, 2013 11:37 am
if you are using MOI with firmware v1.1 or v1.2, please just refer to the thread:
http://www.tbsdtv.com/forum/viewtopic.php?f=93&t=8552if your MOI is still with firmware v1.0, please update, since NFS support is added to the later version.
Thank you.
warumnix
Return to General discussion
