Firmware V2.0.1
A release date? An update? Different versions? ... keep you informed.
Firmware V2.0.1
Postby warumnix » Mon Dec 02, 2013 6:06 pm
Hello All,
the firmware V2.0.1 has just been released, it fixes the problem of "only one of the tuners can work after MOI is powered on".
How to update:
1. from V2.0 to V2.0.1
Copy the files in the firmware V2.0.1 folder to your micro SD card, power on MOI to start the update.
2. from V1.x to V2.0.1 (also refer to http://www.tbsdtv.com/forum/viewtopic.php?f=92&t=8691)
1) Connect RS232 serial cable & install software.
Connect one end of the RS232 cable to MOI, the other end to your PC, install the software:
- for Windows users: TTERMPRO
- for Linux users: minicom
2) Update through micro SD card*
Prepare a formatted micro SD card, copy the file "MOI290-fs.bin" into it, insert it into the SD card slot on MOI, power on MOI, "Enter" uboot quickly (within about 3 seconds after MOI is powered on) and input the command lines:
setenv loadmmcfs 'fatload mmc 0:1 40000000 MOI2900_fs.bin'
setenv updatekfs 'nand erase 50c0000;nand write.yaffs 40000000 50c0000 ${filesize}'
save
then input "re", MOI will start to update.
Download firmware V2.0.1
warumnix
Re: Firmware V2.0.1
Postby skdubg » Fri Dec 06, 2013 10:49 pm
Problem is not solved.
after restart there is only "/dev/dvb/adapter0" available
edit:
a second problem:
the internal epg grabber from tvheadend could not be activated.
skdubg
Re: Firmware V2.0.1
Postby xiaocao » Mon Dec 09, 2013 10:44 am
Hello skdubg,
please try the following:
1). in console, enter the 3 command lines below:
#setenv bootargs 'console=ttySAC0,115200 mem=512M root=/dev/mtdblock3 ethaddr=/$(ethaddr) rootfstype=yaffs2 init=/linuxrc'
#save
#reboot
2). power on MOI, save the print logs and post here
Thank you.
xiaocao
Re: Firmware V2.0.1
Postby skdubg » Mon Dec 09, 2013 9:58 pm
hi,
thanks for reply.
here is the log
CoolTerm Capture 2013-12-09 15-06-49.zip
(9.64 KiB) Downloaded 838 times
skdubg
Re: Firmware V2.0.1
Postby ahmedramze » Tue Dec 10, 2013 5:01 am
how can I upgrade through TFTP server , its possible or not , I'm try to upgrade it remotely vi network.
I put the file in TFTP server with ip 192.168.0.20 and MOI searching for file 'C0A80014.img'
when apply command tftpboot at console
ahmedramze
Re: Firmware V2.0.1
Postby xiaocao » Tue Dec 17, 2013 3:00 pm
hi ahmedramze ,
I'm sorry to tell you that moi can only support for upgrade with SD card. Please refer to http://www.tbsdtv.com/download/ to get more information
Best regards!
xiaocao
Return to Announcements
