MOIPlayer available on App Store
A release date? An update? Different versions? ... keep you informed.
Postby warumnix » Mon May 27, 2013 12:05 pm
MOI has its own palyer now - the MOIPlayer! :D
For the time being it's only for iPad, you can get it from Apple's App Store:
https://itunes.apple.com/app/moi-player/id649376665?mt=8
Please try and send your feedback to us, thank you!
warumnix
Re: MOIPlayer available on App Store
Postby TUISTERa » Mon May 27, 2013 10:13 pm
What about iphone >>>> ????
TUISTERa
Postby steven » Tue May 28, 2013 11:35 am
Hi TUISTERa
Thanks for your feedback. :)
Because IPAD's screen is good to watch TV, maybe later we will
release the iphone version. :)
Postby martinhj » Fri May 31, 2013 3:48 pm
warumnix Wrote:MOI has its own palyer now - the MOIPlayer! :D
Nice to see an ipad app that means the ipad does not need jailbreaking.
Needs a bit more work:
Firstly the default IP address is never saved when changed so it is very irritating having to set this on every launch of the app.
Also the app struggles to play SD content with occasional pauses and stutters and simply crashes if you try and change a channel.
HD content just locks up the app
I am using this over a 5Ghz wireless connection with the MOI connected to the router. I have had no problem playing via XBMC over a 2.4GHz repeated (hence 1/2 the avail bandwidth) connection to a remote XBMC PC so it is not the network causing the problems.
I am sure you will sort these so please take this as positive feedback not criticism (yet ;) )
Martin
martinhj
Postby TUISTERa » Thu Jun 06, 2013 4:53 pm
steven Wrote:Hi TUISTERa
Believe me , iPhone is good for watching too :) And i love your work
TUISTERa
Postby warumnix » Mon Sep 30, 2013 4:56 pm
Hi guys,
to use MOI with your iPhone, now you can try the software combination: TvhClient + OPlayer
They are available on iTunes:
TvhClient
https://itunes.apple.com/gb/app/tvhclient/id638900112?mt=8&ign-mpt=uo%3D4
OPlayer
https://itunes.apple.com/gb/app/oplayer-best-video-music-media/id344784375?mt=8
warumnix
Return to Announcements
