TBS Linux Driver is updated to V160630
Postby Jenny » Fri Jul 01, 2016 10:01 am
Dear all,
Here comes an updated news for you:
TBS Linux Driver is updated to v160630., which added kernel 4.6 support , fixed the following issues:
* fixed issues of some new CAM module can not initialize
* fixed some small bugs
You can download the newest TBS Linux Driver on the following link: http://www.tbsdtv.com/download/document/common/tbs-linux-drivers_v160630.zip
That's all. Thanks for your attention and support. Have a wonderful day!
Best Regards,
Jenny
TBS Technology
Jenny
Re: TBS Linux Driver is updated to V160630
Postby jpeg73 » Tue Jul 05, 2016 5:07 am
Dears,
Thanks a lot for the drivers , but ,
Are you sure you update version ?
because after compit & reboot
a dmesg | grep "TBS version" shows
[ 3.683272] TBS version 160405
Regards
JP
jpeg73
Postby steven » Tue Jul 05, 2016 5:57 pm
Hi jpeg73
Thanks for your feedback this version just a small update ,in future we will focus on the open source driver
if you have interest you can have a look :
viewtopic.php?f=86&t=9960
Kind regards
