Installing TBS 6905 and DD MAX S8!
Postby Ce6at » Fri Jan 22, 2016 4:18 pm
Hi to everyone.
At the moment i am using a TBS 6905 card on my PC.
I use Cesbo astra and everything works fine.
I want to use a Digital Devices Max S8 card but i am wondering if we can make both cards work under linux on the same machine!
Why is it so difficult to have drivers for both cards in kernel so we do not have to compile drivers?
I read that only one of the card may work at any time since its drivers messes up the cards drivers!
Is there anyone that can help?
Ce6at
Re: Installing TBS 6905 and DD MAX S8!
Postby SergioDanielG » Fri Jan 22, 2016 7:10 pm
Hi C6at.
You could try install TBS drivers first and other later.
TBS drivers replace all media kernel, I don't know if the other driver do same.
Any way, can you send me a link of the drivers? I can try install it, too...
Kind regards.
SergioDanielG
Postby Ce6at » Fri Jan 22, 2016 9:23 pm
do you own a DD Max S8 card?
Here is the lnik to the drivers:
https://www.digital-devices.eu/shop/de/ ... sCustom/80
I am expecting to get the card by next Thursday.
I will let you know if i can use both cards at the same time.
Ce6at
Postby SergioDanielG » Fri Jan 22, 2016 10:54 pm
Not, I haven´t got these card. But I can try install it and see if it posible use it with TBS drivers.
All depends of if this driver compile only his modules or all media drivers.
I'll try and then tell you.
Kind regards.
SergioDanielG
Postby SergioDanielG » Fri Jan 22, 2016 11:26 pm
Hi Ce6at.
Good news for you! DD MAX S8 compile with out problems (some unused variable warnings) and my TBS card are working too.
 lsmod | grep ddbridge
ddbridge               21599  0
dvb_core               93643  6 cx23885,saa716x_core,videobuf_dvb,saa716x_tbs_dvb,ddbridge,tbs_pcie_dvb
i2c_core               46012  32 cx23885,cx24116,cx25840,tuner,saa716x_core,saa7134,i2c_piix4,tbs6290fe,tbs6618fe,tbs6680fe,tbs6908fe,tbs6922fe,tbs6923fe,tbs6928fe,tbs6928se,tbs6982fe,tbs6983fe,tbs6982se,tbs6985se,tbs6991fe,tbs6991se,saa716x_tbs_dvb,ddbridge,tea5767,i2c_algo_bit,stb6100,stv090x,v4l2_common,tveeprom,tuner_simple,tbs_pcie_dvb,videodev
Kind regards.
SergioDanielG
Postby Ce6at » Sat Jan 23, 2016 5:22 pm
Dear SergioDaniel,
thank you for your help.
When i get the card i will post my findings.
Hope both cards work together.
Ce6at
Postby Ce6at » Wed Feb 03, 2016 10:20 pm
i did install the DD MAX S8 drivers and i my tbs drivers are not there!
This is what a get:
ddbridge 90112 0
cxd2099 20480 1 ddbridge
dvb_core 126976 1 ddbridge
any idea???
dmesg | grep tbs
[ 11.786958] tbs_pcie_dvb: disagrees about version of symbol dvb_dmxdev_init
[ 11.786960] tbs_pcie_dvb: Unknown symbol dvb_dmxdev_init (err -22)
[ 11.786966] tbs_pcie_dvb: disagrees about version of symbol dvb_ca_en50221_init
[ 11.786967] tbs_pcie_dvb: Unknown symbol dvb_ca_en50221_init (err -22)
[ 11.786989] tbs_pcie_dvb: disagrees about version of symbol dvb_register_adapter
[ 11.786990] tbs_pcie_dvb: Unknown symbol dvb_register_adapter (err -22)
[ 11.786997] tbs_pcie_dvb: disagrees about version of symbol dvb_dmx_swfilter_packets
[ 11.786999] tbs_pcie_dvb: Unknown symbol dvb_dmx_swfilter_packets (err -22)
[ 11.787007] tbs_pcie_dvb: disagrees about version of symbol dvb_dmx_release
[ 11.787008] tbs_pcie_dvb: Unknown symbol dvb_dmx_release (err -22)
[ 11.787013] tbs_pcie_dvb: disagrees about version of symbol dvb_ca_en50221_release
[ 11.787014] tbs_pcie_dvb: Unknown symbol dvb_ca_en50221_release (err -22)
[ 11.787022] tbs_pcie_dvb: disagrees about version of symbol dvb_net_init
[ 11.787023] tbs_pcie_dvb: Unknown symbol dvb_net_init (err -22)
[ 11.787027] tbs_pcie_dvb: disagrees about version of symbol dvb_dmxdev_release
[ 11.787028] tbs_pcie_dvb: Unknown symbol dvb_dmxdev_release (err -22)
[ 11.787033] tbs_pcie_dvb: disagrees about version of symbol dvb_frontend_detach
[ 11.787034] tbs_pcie_dvb: Unknown symbol dvb_frontend_detach (err -22)
[ 11.787038] tbs_pcie_dvb: disagrees about version of symbol dvb_net_release
[ 11.787038] tbs_pcie_dvb: Unknown symbol dvb_net_release (err -22)
[ 11.787043] tbs_pcie_dvb: disagrees about version of symbol dvb_unregister_frontend
[ 11.787044] tbs_pcie_dvb: Unknown symbol dvb_unregister_frontend (err -22)
[ 11.787048] tbs_pcie_dvb: disagrees about version of symbol dvb_register_frontend
[ 11.787049] tbs_pcie_dvb: Unknown symbol dvb_register_frontend (err -22)
[ 11.787051] tbs_pcie_dvb: disagrees about version of symbol dvb_unregister_adapter
[ 11.787052] tbs_pcie_dvb: Unknown symbol dvb_unregister_adapter (err -22)
[ 11.787054] tbs_pcie_dvb: disagrees about version of symbol dvb_dmx_init
[ 11.787055] tbs_pcie_dvb: Unknown symbol dvb_dmx_init (err -22)
dmesg | grep ddbridge
[ 17.476019] ddbridge 0000:03:00.0: DVB: registering adapter 0 frontend 0 (MXL5XX)...
[ 17.523950] ddbridge 0000:03:00.0: DVB: registering adapter 1 frontend 0 (MXL5XX)...
[ 17.571962] ddbridge 0000:03:00.0: DVB: registering adapter 2 frontend 0 (MXL5XX)...
[ 17.619935] ddbridge 0000:03:00.0: DVB: registering adapter 3 frontend 0 (MXL5XX)...
[ 17.620910] ddbridge 0000:03:00.0: DVB: registering adapter 4 frontend 0 (MXL5XX)...
[ 17.621674] ddbridge 0000:03:00.0: DVB: registering adapter 5 frontend 0 (MXL5XX)...
[ 17.622292] ddbridge 0000:03:00.0: DVB: registering adapter 6 frontend 0 (MXL5XX)...
[ 17.622511] ddbridge 0000:03:00.0: DVB: registering adapter 7 frontend 0 (MXL5XX)...
Ce6at
Postby SergioDanielG » Thu Feb 04, 2016 4:03 am
Check if you selected correct drivers for your system un step "v4l/tbs_ ..."
Kind regards
SergioDanielG
Postby Ce6at » Thu Feb 04, 2016 8:00 am
I did choose the 64 bit version.
I try re installing but no luck.
It seems DD drivers overwrite some files.
Ce6at
Postby petwri » Mon May 02, 2016 7:40 pm
Did you figure out how to properly install the driver? I am having a similar issue with my 6928SE on linux 4.5.2.
petwri
Users browsing this forum: No registered users and 13 guests
