Linux 4.2.*
Linux 4.2.*
Postby jumbleoak » Fri Jan 01, 2016 1:17 am
Which version of the drivers should I be using for Linux 4.2.*?
I already had tbs-linux-drivers_v140707. That didn't work (worked fine for previous version of Linux: 3.15.*)
I downloaded latest: tbs-linux-drivers_v151229. That didn't work - couldn't find .config or something
Which should I be using and where do I get it from?
Thanks.
jumbleoak
Re: Linux 4.2.*
Postby updatelee » Fri Jan 01, 2016 1:22 am
You should be using the latest. Sounds like the issue is you don't have the kernel headers installed
Re: Linux 4.2.*
Postby SergioDanielG » Fri Jan 01, 2016 8:14 am
I think as UDL. Try installig kerner headers first and reinstall tbs drivers then.
Kind regards.
SergioDanielG
Re: Linux 4.2.*
Postby SergioDanielG » Fri Jan 01, 2016 11:56 pm
Hi, only for confirm... TBS drivers works with kernel 4.*, specifically tested with kernel 4.3.3.
Kind regards.
SergioDanielG
Re: Linux 4.2.*
Postby jumbleoak » Mon Jan 11, 2016 1:58 pm
Thanks all. I had the 4.2 kernel and 4.3 headers! I upgraded the kernel to 4.3 and it compiled fine.
jumbleoak
