Installing TBS 6905 Ubuntu 15.10 Guide.
Postby Ce6at » Sun Nov 01, 2015 12:35 am
Here is a working guide in order to install the TBS 6905 card under Ubuntu 15.10 x64.
1. Download the latest drivers from TBS site.
Extract the ZIP file tbs-linux-drivers_v151026.zip
unzip tbs-linux-drivers_v151026.zip
2. Extract linux-tbs-drivers.tar.bz2 archive
bzip2 -d linux-tbs-drivers.tar.bz2
tar xvf linux-tbs-drivers.tar
3. Change to driver package directory
cd linux-tbs-drivers
4. Fix the file permissions
At this point, the supplied tar.bz2 is completely knackered in respect of the file permissions. To fix run
find -type d -exec chmod 755 \{\} \;
find -type f -exec chmod 644 \{\} \;
find -name '*.sh' -exec chmod 755 \{\} \;
find -name '*.pl' -exec chmod 755 \{\} \;
5. Select platform architecture
for x86 kernel 3.x (x86 32 bit installations of kernel 3.x)
./v4l/tbs-x86_r3.sh
or for x86 kernel 2.6.x (x86 32 bit installations of kernel 2.6.x)
./v4l/tbs-x86.sh
or for any x86_64 kernel (x86 64 bit installations of Linux)
./v4l/tbs-x86_64.sh
You should then receive a message along these lines:
TBS drivers configured for [NAME OF PLATFORM] platform.
where [NAME OF PLATFORM] is x86_r3 or x86 or 86_64
6. Build the driver. Recompiles v4l for a wide range of cards, currently about 500, will take many minutes. We're ready to build; add -j3 parameter for make command line for a faster build on a dual core machine, -j5 on a quad core machine, etc.
make
If you get -bash: make: command not found, then sudo apt-get install build-essential
7. Install driver. Existing drivers for other v4l related hardware, such as lirc could also get updated.
sudo make install
8A. Reboot
sudo reboot
In case you get the following error:
module verification failed: signature and/or required key missing - tainting kernel
[ 3.116311] tbs_pcie_dvb: disagrees about version of symbol dvb_dmxdev_init
[ 3.116315] tbs_pcie_dvb: Unknown symbol dvb_dmxdev_init (err -22)
[ 3.116325] tbs_pcie_dvb: disagrees about version of symbol dvb_ca_en50221_init
[ 3.116327] tbs_pcie_dvb: Unknown symbol dvb_ca_en50221_init (err -22)
[ 3.116356] tbs_pcie_dvb: disagrees about version of symbol dvb_register_adapter
[ 3.116359] tbs_pcie_dvb: Unknown symbol dvb_register_adapter (err -22)
[ 3.116370] tbs_pcie_dvb: disagrees about version of symbol dvb_dmx_swfilter_packets
[ 3.116372] tbs_pcie_dvb: Unknown symbol dvb_dmx_swfilter_packets (err -22)
[ 3.116482] tbs_pcie_dvb: disagrees about version of symbol dvb_dmx_release
[ 3.116486] tbs_pcie_dvb: Unknown symbol dvb_dmx_release (err -22)
[ 3.116493] tbs_pcie_dvb: disagrees about version of symbol dvb_ca_en50221_release
[ 3.116539] tbs_pcie_dvb: Unknown symbol dvb_ca_en50221_release (err -22)
[ 3.116680] tbs_pcie_dvb: disagrees about version of symbol dvb_net_init
[ 3.116683] tbs_pcie_dvb: Unknown symbol dvb_net_init (err -22)
[ 3.116690] tbs_pcie_dvb: disagrees about version of symbol dvb_dmxdev_release
[ 3.116693] tbs_pcie_dvb: Unknown symbol dvb_dmxdev_release (err -22)
[ 3.116716] tbs_pcie_dvb: disagrees about version of symbol dvb_frontend_detach
[ 3.116719] tbs_pcie_dvb: Unknown symbol dvb_frontend_detach (err -22)
[ 3.116723] tbs_pcie_dvb: disagrees about version of symbol dvb_net_release
[ 3.116726] tbs_pcie_dvb: Unknown symbol dvb_net_release (err -22)
[ 3.116731] tbs_pcie_dvb: disagrees about version of symbol dvb_unregister_frontend
[ 3.116733] tbs_pcie_dvb: Unknown symbol dvb_unregister_frontend (err -22)
[ 3.116739] tbs_pcie_dvb: disagrees about version of symbol dvb_register_frontend
[ 3.116741] tbs_pcie_dvb: Unknown symbol dvb_register_frontend (err -22)
[ 3.116745] tbs_pcie_dvb: disagrees about version of symbol dvb_unregister_adapter
[ 3.116747] tbs_pcie_dvb: Unknown symbol dvb_unregister_adapter (err -22)
[ 3.116750] tbs_pcie_dvb: disagrees about version of symbol dvb_dmx_init
[ 3.116752] tbs_pcie_dvb: Unknown symbol dvb_dmx_init (err -22
delete all files in directory
/lib/modules/4.2.0-16-generic/kernel/drivers/media/
then i compile drivers again:
sudo make
then install drivers:
sudo make install
reboot:
sudo reboot
Check if card is installed:
lsdvb
Version: 0.0.4
Copyright (C) Manu Abraham
TBS PCIE (544:6178 6905:1) on PCI Domain:0 Bus:1 Device:0 Function:0
DEVICE:0 ADAPTER:0 FRONTEND:0 (TurboSight TBS 6905 DVBS/S2 frontend)
FE_QPSK Fmin=950MHz Fmax=2150MHz
DEVICE:0 ADAPTER:3 FRONTEND:0 (TurboSight TBS 6905 DVBS/S2 frontend)
DEVICE:0 ADAPTER:2 FRONTEND:0 (TurboSight TBS 6905 DVBS/S2 frontend)
DEVICE:0 ADAPTER:1 FRONTEND:0 (TurboSight TBS 6905 DVBS/S2 frontend)
Ce6at
Re: Installing TBS 6905 Ubuntu 15.10 Guide.
Postby BlueSky » Sun Nov 01, 2015 3:07 pm
I have never had to mess with permissions when installing TBS drivers, but then I do it a little bit differently:
Browse to http://www.tbsdtv.com/download/ and find the latest drivers for your card. Right click on the link and copy the link location.
Then:
cd Downloads
wget http://www.tbsdtv.com/download/document ... xxxxxx.zip <— Paste the link here
unzip tbs-linux-drivers_vxxxxxx.zip <— Replace the filename with that of the one you just downloaded
Depending on your kernel version and if the kernel is x86 or x86_64 (check output of ‘uname -a’) do ONE of the following:
– for x86 kernel 3.x (x86 32 bit installations of kernel 3.x): sudo ./v4l/tbs-x86_r3.sh
– for x86 kernel 2.6.x (x86 32 bit installations of kernel 2.6.x): sudo ./v4l/tbs-x86.sh
– for any x86_64 kernel (x86 64 bit installations of Linux): sudo ./v4l/tbs-x86_64.sh
Then:
sudo make && sudo make install
sudo reboot
After the reboot you can test that the tuners are working with either or both of the following:
dmesg | grep -i dvb
ls -l /dev/dvb
These instructions are modified from an article that no longer appears to be online. As I say, I have never had issues with permissions when using this method. I wonder if it's because you have an extra step involving bzip2 (which AFAIK is unnecessary) and/or your tar command doesn't include the "j" option. I think that by doing the step with bzip2 you might actually be causing problems for yourself, but maybe there's some reason you need to do that? Anyway, I'm just saying what has always worked for me.
BlueSky
Postby Maxpower » Tue Nov 03, 2015 3:03 am
Agree with BlueSKy . . . . the issue is with "your tar command doesn't include the "j" option"
I basically use the method Ce6at is describing but the "j" option is crucial. :-)
Maxpower
Postby Ce6at » Wed Nov 04, 2015 12:33 am
the -j options is used for a bzip2 file.
We decompress the bz2 file with bzip2 and that give us a tar file.
Ce6at
Postby BlueSky » Fri Nov 06, 2015 7:48 am
Ce6at Wrote:Hi,
So in other words, you're doing it the hard way. Got it.
BlueSky
Postby BlueSky » Fri Nov 20, 2015 3:12 am
lalacurf121 Wrote:I have never had to mess with permissions when installing TBS drivers,
I don't think anyone has, other than the person who started this thread (and anyone who follows his overly-complicated instructions).
BlueSky
Postby orson » Fri Nov 20, 2015 3:24 am
The reason for (not)having permission problems migth be that most people unzip+untar it as root, and also compile it as root.
As root can read them -> no problem.
As a normal user -> problem.
At least that's the reason why I also have permission problems and have to correct them before start building the driver.
orson
