BlindSan and RAW DiSEqC comamnds?
Postby lujo » Wed Jun 04, 2014 12:38 pm
I am using BlindScan to scan for transponders so that I can use those for other software.
The problem is that I am using Triax 78cm with Moteck-2100A and with BlindScan I cannot send DiSEqC 1.2 commands.
I don't think that it should be difficult to add extra field for example RAW DiSEqC commands.
With E0 31 6B 01 I can move dish to Position 1
And can we get sorting optios, so that output is sorted from the lowest to highest transponder:
11023.25
12525.00
12725.00
Will this be implemented?
lujo
