DVBDream V22C
DVBDream V22C
Postby warumnix » Tue Oct 23, 2012 10:13 am
DVBDream for TBS series products is updated to V22C.
DOWNLOAD
warumnix
Re: DVBDream V22C
Postby Peon » Tue Nov 06, 2012 1:40 am
I have a problem with DVB Dream. Even with the latest version 2.2cOEM TBS5925 does not work. No lock at any frequency. Satellite Prof7301 card works without problems. What is wrong? I have the latest driver, Win XP SP3. With Alt DVB SmartDVB, EBSPro, CrazyScan and other software works normally. Thanks for any help
Peon
Re: DVBDream V22C
Postby steven » Tue Nov 06, 2012 9:16 am
Hi Peon
Thanks for your test report,We will check this problem now,any progress we will contact you
as soon as possible.
Re: DVBDream V22C
Postby smile » Tue Nov 06, 2012 10:28 am
Hi peon
Thanks for your test report ! I just had a test with the DVBDream V22C. it works normally! here is the part of the result:Image
And would you mind try to use the"Manual Scan"to lock the single Frequency? whether it can be locked?
Thanks!
Best regards!
smile
Re: DVBDream V22C
Postby Peon » Tue Nov 06, 2012 11:15 pm
Thanks for the quick reply.
The results of my tests:
Automatic tuning works sometimes on the third, fourth attempt. About half of the transponders tuned. The second half finds the TP, but not tune channels.
Manual tuning works.
While watching the program for some time and the picture freezes after switching to another program does not work anymore. It does not even tuning. It is not enough to restart dvbdream. I have to disable and re-enable TBS5925. (turning off the power).
PC freezes sometimes when you switch to another program. It helps only a hard reset
I tested it on two PC with WINXP SP3 with the same result.
Thanks for any advice
Peon
Re: DVBDream V22C
Postby SquareEyes » Fri Nov 16, 2012 3:13 am
Can anyone confirm if v22c allows Picture In Picture viewing of DVB-T / DVB-T2?
The last time I tried v17c I think it was not possible to watch PiP. I didn't want to install it and then have to uninstall it again. Usually I find that if I uninstall DVBDream it also seems to uninstall TBSViewer - I think they share the same dlls.
It would also be useful to know what video codecs people are using to watch DVB-T2 HD programmes. I have tried different encoders and codecs etc with the previous version but the H.264 bar at the bottom keep filling and reloading and I only get a frame each time.
SquareEyes
Re: DVBDream V22C
Postby tbsuser18 » Fri Dec 06, 2013 11:06 am
Peon Wrote:I have a problem with DVB Dream. Even with the latest version 2.2cOEM TBS5925 does not work. No lock at any frequency. Satellite Prof7301 card works without problems. What is wrong? I have the latest driver, Win XP SP3. With Alt DVB SmartDVB, EBSPro, CrazyScan and other software works normally. Thanks for any help
has this issue been resolved? because i am also facing problem with dvb dream auto scanning of frequencies and it sometimes tunes previous frequency channels and sometimes says no channels found
tbsuser18
