Linux driver V121021
Postby warumnix » Tue Oct 23, 2012 10:02 am
Dear All,
TBS Linux driver is updated to V121021 :
DOWNLOAD
* Improve compatibility with Linux kernel version 3.6.x, i.e. currently supported kernel range is from version 2.6.31 to version 3.6.x
* Add final support for TBS 6926
* Add support for dBm reporting with TBS 6982
* Preliminary fix for unstable lock with TBS 6991 on some transponders
* Improve performance of TBS 6982 in case lock can't be acquired
* numerous smaller fixes
try it out and let us know how it works! Thanks!
TBS support team
warumnix
Re: Linux driver V121021
Postby SergioDanielG » Fri Oct 26, 2012 7:29 am
Hi warumnix.
What happened with linux-tbs-sources/v4l/tbs* scripts?
I compiled today the new version but only TBS6920 was recognized.
More late I'll put more details.
Thanks in advance
SergioDanielG
Postby steven » Fri Oct 26, 2012 9:46 am
Hi SergioDanielG
we have two linux driver :
http://www.tbsdtv.com/download/document ... 121021.zip
some card use different version,Can you make sure that you have installed both
linux driver?
Kind Regard
Postby SergioDanielG » Fri Oct 26, 2012 9:56 am
Hi steven. Yes of course!
Give me some minutes and i'll report it again.
SergioDanielG
Postby SergioDanielG » Fri Oct 26, 2012 11:06 am
Well, I install tbs driver (not source) and now TBS6925 is reconogzed, but TBS6982 not.
The one reference about TBS6982 in dmesg is
tbs6928fe: module license 'TurboSight Proprietary: www.tbsdtv.com' taints kernel.
Disabling lock debugging due to kernel taint
SergioDanielG
Postby SergioDanielG » Sat Oct 27, 2012 11:21 am
Now it's all ok. Why? I really don't know.... :mrgreen:
After reboot tbs6928 was not found, but after shootdown and restart and no more problems.
Thanks for all
SergioDanielG
Postby steven » Sat Oct 27, 2012 3:29 pm
Hi SergioDanielG
Thanks for your update,and we have tested it too,it can detect TBS6928 and TBS6982,we will have more test in other computer
and send the test report later. :D
Postby crazycat » Sat Oct 27, 2012 11:58 pm
so http://www.tbsdtv.com/download/document ... 121021.zip contain only open-source drivers (+firmwares).
http://www.tbsdtv.com/download/document ... 121021.zip contain all drivers (including binary modules and firmwares).
i have one question - why 5925 driver with some binary module ?:) look like this module only control LNB power switching and this 100% similar to another TBS USB with 100% open-source drivers (5910, 5920, 5928, 5980) ? Some peoples want use TBS USB devices with Linux-based STB (MIPS, SH4) and need 100% open-source drivers for porting (most users want 5925 for 16/32APSK receiving)
Postby updatelee » Sat Nov 10, 2012 11:52 am
Its buggering me up as well, I cant add my spectrum scan code because if I add anything to the dvb_fronend_ops struct it now mismatch's with the precompiled .o and I get seg faults. and because dvb_frontend_ops struct is common to multiple dvb devices I cant have my prof 7500 (with sprectrum scan) and the TBS6925 (without spectrum scan) its an all or nothing situation, I either use the Prof or the TBS not both.
what chip are you using for the voltage controller ? the lattice PLD ? I really dont see why you could opensrc the driver that controls that.
There is alot of potential in this card thats being held back by a simple little file.
