tbs6902 and tvheadend
Postby woooow » Wed Sep 10, 2025 7:29 pm
Hello, i have one question.
Why tbs6902 not show correctly signal strengh like example in attachment. Signal is locked and not update, when option "force old status" is unchecked. When I check this option "db" and "dbm" is now "%" and start to update every 5 seconds (time I set in my configuration).
woooow
Re: tbs6902 and tvheadend
Postby smile » Tue Sep 23, 2025 11:27 am
Hello
This is the DVB API version issue.Using dBm provides greater accuracy. The percentage is a relatively subjective value.
Best Regards
smile
Users browsing this forum: No registered users and 11 guests
