tbs6281se v2 scan dvb-c
Postby starman » Thu Nov 14, 2024 5:13 pm
Hi!
I have a tbs6281se v2 card and I can't get it to work.
Using the latest drivers (https://github.com/tbsdtv/linux_media/wiki).
I need dvb-c mode
lspci -vvv
01:00.0 Multimedia controller: TBS Technologies DVB Tuner PCIe Card
   Subsystem: Device 6281:0003
   Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
   Interrupt: pin A routed to IRQ 136
   Region 0: Memory at a0900000 (32-bit, non-prefetchable) [size=256K]
   Capabilities: [70] MSI: Enable+ Count=1/1 Maskable- 64bit+
      Address: 00000000fee06000  Data: 0022
   Capabilities: [90] Express (v1) Endpoint, MSI 00
      DevCap:   MaxPayload 128 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
         ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0W
      DevCtl:   CorrErr- NonFatalErr- FatalErr- UnsupReq-
      DevSta:   CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
      LnkCap:   Port #0, Speed 2.5GT/s, Width x1, ASPM L0s, Exit Latency L0s unlimited
         ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
      LnkCtl:   ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
      LnkSta:   Speed 2.5GT/s, Width x1
         TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
   Capabilities: [100 v1] Device Serial Number 00-00-00-00-00-00-00-00
   Kernel driver in use: TBSECP3 driver
   Kernel modules: tbsecp3
dmesg | grep frontend
[    2.864029] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 0 frontend 0 (TurboSight TBS 6281TD DVB-T/T2/C ISDB-T/C ATSC1.0)...
[    2.988004] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6281TD DVB-T/T2/C ISDB-T/C ATSC1.0)...
lsmod
Module                  Size  Used by
snd_hda_codec_hdmi     94208  1
snd_hda_codec_realtek   200704  1
snd_hda_codec_generic   122880  1 snd_hda_codec_realtek
xe                   2711552  0
drm_gpuvm              45056  1 xe
drm_exec               12288  2 drm_gpuvm,xe
gpu_sched              61440  1 xe
drm_suballoc_helper    16384  1 xe
drm_ttm_helper         12288  1 xe
snd_sof_pci_intel_tgl    12288  0
snd_sof_intel_hda_common   217088  1 snd_sof_pci_intel_tgl
soundwire_intel        73728  1 snd_sof_intel_hda_common
ppdev                  24576  0
cxd2878                65536  2
snd_sof_intel_hda_mlink    45056  2 soundwire_intel,snd_sof_intel_hda_common
soundwire_cadence      40960  1 soundwire_intel
snd_sof_intel_hda      24576  1 snd_sof_intel_hda_common
snd_sof_pci            24576  2 snd_sof_intel_hda_common,snd_sof_pci_intel_tgl
snd_sof_xtensa_dsp     12288  1 snd_sof_intel_hda_common
snd_sof               380928  3 snd_sof_pci,snd_sof_intel_hda_common,snd_sof_intel_hda
i915                 4280320  1
snd_sof_utils          16384  1 snd_sof
snd_soc_hdac_hda       24576  1 snd_sof_intel_hda_common
snd_hda_ext_core       32768  4 snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_sof_intel_hda_mlink,snd_sof_intel_hda
snd_soc_acpi_intel_match    98304  2 snd_sof_intel_hda_common,snd_sof_pci_intel_tgl
snd_soc_acpi           16384  2 snd_soc_acpi_intel_match,snd_sof_intel_hda_common
soundwire_generic_allocation    12288  1 soundwire_intel
soundwire_bus         110592  3 soundwire_intel,soundwire_generic_allocation,soundwire_cadence
snd_soc_core          438272  4 soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hda
snd_compress           28672  1 snd_soc_core
ac97_bus               12288  1 snd_soc_core
snd_pcm_dmaengine      16384  1 snd_soc_core
binfmt_misc            24576  1
intel_rapl_msr         20480  0
intel_rapl_common      40960  1 intel_rapl_msr
snd_hda_intel          61440  0
intel_uncore_frequency    16384  0
snd_intel_dspcfg       36864  3 snd_hda_intel,snd_sof,snd_sof_intel_hda_common
intel_uncore_frequency_common    16384  1 intel_uncore_frequency
snd_intel_sdw_acpi     16384  2 snd_sof_intel_hda_common,snd_intel_dspcfg
snd_hda_codec         204800  6 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek,snd_soc_hdac_hda,snd_sof_intel_hda
drm_buddy              20480  2 xe,i915
x86_pkg_temp_thermal    20480  0
ttm                   110592  3 drm_ttm_helper,xe,i915
cmdlinepart            12288  0
snd_hda_core          139264  9 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_sof_intel_hda
tbsecp3                81920  0
intel_powerclamp       24576  0
spi_nor               163840  0
gx1133                 40960  1 tbsecp3
snd_hwdep              20480  1 snd_hda_codec
drm_display_helper    237568  2 xe,i915
nls_iso8859_1          12288  1
mei_hdcp               28672  0
mfd_aaeon              12288  0
tas2101                32768  1 tbsecp3
eeepc_wmi              12288  0
mtd                    98304  3 spi_nor,cmdlinepart
ee1004                 16384  0
snd_pcm               192512  11 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_compress,snd_soc_core,snd_sof_utils,snd_hda_core,snd_pcm_dmaengine
mei_pxp                16384  0
asus_wmi               86016  2 eeepc_wmi,mfd_aaeon
coretemp               24576  0
dvb_core              184320  1 tbsecp3
cec                    94208  3 drm_display_helper,xe,i915
i2c_mux                12288  1 gx1133
snd_timer              49152  1 snd_pcm
ledtrig_audio          12288  1 asus_wmi
videobuf2_vmalloc      20480  1 dvb_core
intel_cstate           24576  0
parport_pc             53248  0
videobuf2_memops       16384  1 videobuf2_vmalloc
spi_intel_pci          12288  0
snd                   143360  11 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_sof,snd_timer,snd_compress,snd_soc_core,snd_pcm
sparse_keymap          12288  1 asus_wmi
intel_pmc_core        118784  0
rc_core                73728  1 cec
i2c_i801               36864  0
mei_me                 53248  2
videobuf2_common       90112  3 videobuf2_vmalloc,dvb_core,videobuf2_memops
platform_profile       12288  1 asus_wmi
soundcore              16384  1 snd
wmi_bmof               12288  0
intel_vsec             20480  1 intel_pmc_core
mc                     81920  2 dvb_core,videobuf2_common
mei                   172032  5 mei_hdcp,mei_pxp,mei_me
i2c_smbus              16384  1 i2c_i801
i2c_algo_bit           16384  2 xe,i915
spi_intel              32768  1 spi_intel_pci
parport                73728  2 parport_pc,ppdev
cfg80211             1323008  0
pmt_telemetry          16384  1 intel_pmc_core
pmt_class              12288  1 pmt_telemetry
input_leds             12288  0
acpi_tad               20480  0
acpi_pad              184320  0
joydev                 32768  0
mac_hid                12288  0
sch_fq_codel           24576  2
dm_multipath           45056  0
efi_pstore             12288  0
nfnetlink              20480  2
dmi_sysfs              24576  0
ip_tables              32768  0
x_tables               65536  1 ip_tables
autofs4                57344  2
btrfs                2019328  0
blake2b_generic        24576  0
raid10                 73728  0
raid456               192512  0
async_raid6_recov      20480  1 raid456
async_memcpy           16384  2 raid456,async_raid6_recov
async_pq               20480  2 raid456,async_raid6_recov
async_xor              16384  3 async_pq,raid456,async_raid6_recov
async_tx               16384  5 async_pq,async_memcpy,async_xor,raid456,async_raid6_recov
xor                    20480  2 async_xor,btrfs
raid6_pq              126976  4 async_pq,btrfs,raid456,async_raid6_recov
libcrc32c              12288  2 btrfs,raid456
raid1                  57344  0
raid0                  24576  0
hid_generic            12288  0
usbhid                 77824  0
hid                   180224  2 usbhid,hid_generic
crct10dif_pclmul       12288  1
crc32_pclmul           12288  0
polyval_clmulni        12288  0
nvme                   61440  2
polyval_generic        12288  1 polyval_clmulni
ghash_clmulni_intel    16384  0
sha256_ssse3           32768  0
nvme_core             208896  3 nvme
sha1_ssse3             32768  0
e1000e                356352  0
ahci                   49152  0
intel_lpss_pci         24576  0
intel_lpss             12288  1 intel_lpss_pci
xhci_pci               24576  0
libahci                53248  1 ahci
nvme_auth              28672  1 nvme_core
idma64                 20480  0
xhci_pci_renesas       20480  1 xhci_pci
video                  73728  3 asus_wmi,xe,i915
wmi                    28672  4 video,asus_wmi,wmi_bmof,mfd_aaeon
pinctrl_tigerlake      28672  0
aesni_intel           356352  0
crypto_simd            16384  1 aesni_intel
cryptd                 24576  2 crypto_simd,ghash_clmulni_intel
w_scan -fc
w_scan -fc
scan type CABLE, channellist 4
output format vdr-2.0
Info: using DVB adapter auto detection.
        /dev/dvb/adapter0/frontend0 -> CABLE "TurboSight TBS 6281TD DVB-T/T2/C ISDB-T/C ATSC1.0": very good :-))
Using CABLE frontend (adapter /dev/dvb/adapter0/frontend0)
Using DVB API 5.12
frontend 'TurboSight TBS 6281TD DVB-T/T2/C ISDB-T/C ATSC1.0' supports
INVERSION_AUTO
QAM_AUTO
FEC_AUTO
FREQ (47.00MHz ... 862.00MHz)
SRATE (1.700MSym/s ... 7.200MSym/s)
474000: sr6900 (time: 00:00.000) sr6875 (time: 00:03.383)
858000: sr6900 (time: 05:21.913) sr6875 (time: 05:25.248)
ERROR: Sorry - i couldn't get any working frequency/transponder
 Nothing to scan!!
starman
Re: tbs6281se v2 scan dvb-c
Postby smile » Mon Nov 18, 2024 10:46 am
Hello
Do you have check your signal cable with other device?
Best Regards
smile
Postby starman » Mon Nov 18, 2024 1:07 pm
smile Wrote:Do you have check your signal cable with other device?
Hello
I only have TVs and homatics box r 4k plus+tuner, there is an excellent signal
Ubuntu 24.04.1 LTS (GNU/Linux 6.8.0-48-generic x86_64)
Maybe something needs to be enabled in the kernel?
starman
Postby starman » Thu Nov 28, 2024 3:38 am
Hello!
The problem is solved, many thanks to TBS support team. I had a weak signal, installing a signal amplifier helped. All available services were found, everything works great!
starman
