Problem detecting tbs pcie cards-Ubuntu 20.04.5 /kernel 5.15
Postby bobben » Mon Jan 30, 2023 3:18 am
Hopefully the problem is easy to fix on basis of the info below.
Computer : Lenovo Thinkstation P330 gen2
Tried with PCIe speed auto and gen1.
lsb_release -a
Distributor ID: Ubuntu
Description: Ubuntu 20.04.5 LTS
Release: 20.04
Codename: focal
uname -r
5.15.0-58-generic
lspci
01:00.0 Multimedia controller: TBS Technologies DVB Tuner PCIe Card
03:00.0 Multimedia controller: TBS Technologies DVB Tuner PCIe Card
(both pcie cards verified ok in windows 11)
Drivers seems to be successfully installed in:
/lib/modules/5.15.0-58-generic/updates/extra/media
-No errors during the process
lsdvb
Version: 0.0.4
Copyright (C) Manu Abraham
ERROR: Opening /sys/class/dvb directory
dmesg | grep -i 'dvb'
nothing is detected
I have followed this guide https://github.com/tbsdtv/linux_media/wiki
I have installed linux drivers successfully several times before in ubuntu 20.04 (kernel 5.8) but then the drivers gets located in
/lib/modules/'uname -r'/kernel/drivers/media
bobben
Re: Problem detecting tbs pcie cards-Ubuntu 20.04.5 /kernel
Postby bobben » Mon Jan 30, 2023 3:34 am
Got it working. Drivers was installed correctly.
Solution : turned off secure boot in BIOS .
bobben
