libpcre2-posix.so.3 prevents driver from building(solved)
Postby pchristy » Sat May 29, 2021 6:15 pm
System: Slackware64-current. Kernel 5.10.40
Problem: Driver fails to build. Driver is expecting libpcre2-posix.so.2, which has been replaced by libpcre2-posix.so.3 (library version bump)
Pete
pchristy
Re: libpcre2-posix.so.3 prevents driver from building
Postby steven » Sun May 30, 2021 7:12 am
Hi Sir
please have a try with this package :
# wget http://www.tbsdtv.com/download/document/linux/media_build-2021-05-08.tar.bz2
#tar jxvf media_build-2021-05-08.tar.bz2
#cd media_build
#./install.sh
#reboot
thanks
Postby pchristy » Mon May 31, 2021 9:30 pm
Yes, that worked fine! Thank you very much!
Much easier than the old way of building / installing, too! :)
Pete
pchristy
