linux driver for tbs 5520se
Postby chuliu » Fri Apr 09, 2021 7:26 pm
I followed this tutorial https://www.linuxtv.org/wiki/index.php/ ... stallation
and tried to install driver for tbs 5520se.
I installed open source driver "forked driver" but the command found nothing "dmesg | grep 'DVB: registering'"
and I deleted the folder where the downloaded files are because I don't know how to uninstall driver for linux.
Then I installed tbs closed end driver for 5 times or so. Again I cannot find anything by the command "ls -al dev/dvb"
I am a noob to linux. How do I uninstall the drivers and how I can install it correctly?
chuliu
Re: linux driver for tbs 5520se
Postby steven » Fri Apr 16, 2021 2:39 pm
Hi Sir
# wget http://www.tbsdtv.com/download/document/linux/media_build-2021-02-04.tar.bz2
#tar jxvf media_build-2021-02-04.tar.bz2
#cd media_build
#./install.sh
#reboot
