Unable to compile open drivers against Fedora 32 5.10.12-100
Postby pinsb » Sat Feb 06, 2021 6:36 am
Have been compiling fine on Fedora until recently, now fails during ./install.sh with following.
Does NOT create media subdir in /lib/modules/5.10.12-100.fc32.x86_64/kernel/drivers as expected, original media subdir in that path changed to media.orig to avoid conflict before the build.
I'm trying to build media_build-2020-12-04.tar.bz2 using the standard readme instructions, have tried as randomuser, sudo randomuser and root, all fail same way.
make[2]: *** [Makefile:1806: /home/randomuser/Desktop/tbs_media_build/media_build/v4l] Error 2
make[2]: Leaving directory '/usr/src/kernels/5.10.12-100.fc32.x86_64'
make[1]: *** [Makefile:52: default] Error 2
make[1]: Leaving directory '/home/randomuser/Desktop/tbs_media_build/media_build/v4l'
V4L drivers installing...
make -C /home/randomuser/Desktop/tbs_media_build/media_build/v4l install
make[1]: Entering directory '/home/randomuser/Desktop/tbs_media_build/media_build/v4l'
Installing kernel modules under /lib/modules/5.10.12-100.fc32.x86_64/kernel/drivers/media/:
/sbin/depmod -a 5.10.12-100.fc32.x86_64
make -C firmware install
make[2]: Entering directory '/home/randomuser/Desktop/tbs_media_build/media_build/v4l/firmware'
Installing firmwares at /lib/firmware:
make[2]: Leaving directory '/home/randomuser/Desktop/tbs_media_build/media_build/v4l/firmware'
V4L drivers installation done
You need to reboot...
HELP....the cricket test matches are on FTA and I want to record them.
pinsb
