Clean Sweep Uninstaller for TBS drivers
Postby Youknowme02 » Tue Oct 20, 2020 3:11 am
I wanted to know if there is a TBS software to uninstaller software that will allow you to uninstall ALL THE TBS OLD DRIVERS COMPLETELY, like a clean sweep?
Youknowme02
Re: Clean Sweep Uninstaller for TBS drivers
Postby steven » Wed Oct 21, 2020 10:50 am
hi Sir
you are using the card under windows or linux ?
windows we have uninstall application , for linux you can try delete the media folder (# sudo rm -rf /lib/modules/`uname -r`/kernel/drivers/media/)
then install the driver again .
kind Regards
Postby Youknowme02 » Thu Oct 22, 2020 12:28 am
Thanks I am using a windows 7, the windows uninstall program Does Not do a clean sweep, it leave behind hidden files, and other files, I was looking for a clean sweep program.
Youknowme02
Postby steven » Thu Oct 22, 2020 9:59 am
you can go to
C:\Windows\System32\drivers folder delete the sys file
C:\Windows\INF check the OEM*.inf file
thanks
Postby mohsh86 » Sat Dec 19, 2020 7:03 pm
steven Wrote:hi Sir
kind Regards
how do you do that for linux?
delete all drivers and firmware files?
mohsh86
