Driver for 6909X Ubuntu 18.4
Postby satesco » Sat Feb 23, 2019 7:25 pm
I would like to know if there are drivers for tbs6909x and if I can install(including tbs6903x) on Ubuntu 18.4?
Thanks :D
satesco
Re: Driver for 6909X Ubuntu 18.4
Postby steven » Wed Feb 27, 2019 9:59 am
hi
you can direct try the driver at github :
support the kernel upto 4.20
thanks
Postby smf » Sat Mar 09, 2019 8:20 pm
The stated process may well cover numerous tuners. I used it with a 6280 and it works perfectly. The only downside is every time Ubuntu kernel updates are installed it may break it again and need a full reinstall after deleting the media and media_build folders,
smf
