TBS5580 Windows 10 Driver v1.0.0.2
Postby tsygam » Sun Mar 11, 2018 6:04 pm
Thank you for the driver update, though what changed in this version?
It would be great to put some news on this - probably someone would not notice that the downloads section changed.
tsygam
Re: TBS5580 Windows 10 Driver v1.0.0.2
Postby smile » Tue Mar 13, 2018 2:44 pm
HI
Thanks for your advise. it is our negligence.
it was update the chip firmware. and fixed a bug which sometimes it can not locked on dvbt/t2 mode .
Best Regards
smile
Postby Username » Mon May 21, 2018 11:03 pm
Do you have an TBS5580 home?
I have some Questions about.
Username
Postby tsygam » Tue May 22, 2018 1:05 am
yes i have. please feel free to ask.
tsygam
Postby Username » Tue May 22, 2018 3:50 am
I travel often from Hotel to Hotel and the Hotel TV Sucks. :evil:
So I will connect this Multi Receiver to the Hotel TV System and Scan for DVB-T2, DVB-C and DVB-S2.
How does it work for you? Do you have any trouble with it?
Do you use the CI Slot?
Username
Postby tsygam » Wed May 23, 2018 12:47 am
You will have to use the ChangeMode tool to switch between dvb-s/dvb-t/dvb-c modes and to do so, you may have to restart your dvb software.
I have no idea why TBS cannot in-built this functionality into the driver and provide relevant API extension to DVB software programmers (in linux you do not need to use this stupid ChangeMode tool), but i never got a clear answer from support. Unfortunately this "ChangeMode functionality" is not clearly documented, and if i knew this, I probably would not buy this card. I do not use CI slot.
I also not sure if each hotel provides just a "clear" dvb-s/t/c/etc signal, or they transcode/transmodulate signals to smth. common
tsygam
Postby Username » Wed May 23, 2018 12:54 am
So I have "just" use there tool to switch between the DVB Mode?
With Software can I use for reception?
Username
Postby tsygam » Wed May 23, 2018 3:15 am
i prefer SmartDVB and/or mediaportal
tsygam
Users browsing this forum: Bing [Bot] and 3 guests
