Problem with drivers for TBS6290 and TBS6209
Postby proseiko » Thu Jul 06, 2017 10:32 pm
Hello fellas,
I’m wondering if someone can help me. I have problem with the drivers…
I have 3 PCI-e tv tuner cards ( 2xTBS6290 and 1x 6209 )
- 2 x TBS6290 – each one support 2 CAM modules and I have 3 modules from 4 installed.
- 1 x TBS6209 – which is working properly
My problem:
When I’ve installed the drivers for TBS 6209 – it also installs the drivers for TBS6290 but it detects just one CAM module per (PCI-e) card. The second CAM module is showing that it’s not inserted (empty) but it is inserted properly.
I’ll add some screenshots so you can get a better idea what I’m talking about….
With Latest drivers for TBS6290 It’s working perfectly but doesn’t install the TBS6209
With the latest drivers for TBS6209
My system is:
Ubuntu 15:10
Kernel: 4.2.0-16-generic
Has anyone had the same problem and if not can you give me advise what to do or what to try ? :cry:
proseiko
Re: Problem with drivers for TBS6290 and TBS6209
Postby steven » Fri Jul 07, 2017 4:22 pm
Please check your email already reply you
