driver 2.0.0.6 not work for Windows 10 (Anniversary Update)
Postby imago » Sat Jan 21, 2017 7:08 pm
good day
there are plans work to release drivers for Windows 10 version 1607 (Anniversary Update), or what are the options to work on 2.0.0.6 TBS5925?
ps I tested on two different motherboards Z87E-ITX and Z87-DELUXE, Windows 10 version 1607 (Anniversary Update) all unknown device. In Linux CrazyCat and TBS driver the device works without problems
imago
Re: driver 2.0.0.6 not work for Windows 10 (Anniversary Upda
Postby MrFloppy » Fri Aug 04, 2017 5:20 pm
Just got a TBS5925 as well and ran into a similar problem on W10AU: code 10, could not start device.
The driver from the CD-ROM installs fine, but I dont get any signal. I'ld like to be able to use the latest drivers as offered to test the setup.
MrFloppy
Postby imago » Thu Aug 31, 2017 11:20 pm
The problem was solved by installation Windows 10 (assembly of 15063.540) Version 1703
After updating all works
ps (assembly of 14xxx) Does not work
imago
