A lot of problems with TBS6522 and DVB-C
Postby Newtman » Thu Dec 29, 2016 10:46 am
I have got my first TBS6522 but the experience isn't good yet.
DVB-T, ISDB-T and DVB-S2 work nice but DVB-C (my provider is Annex B) don't work in Windows using DVB-Dream and latest driver and fail too in Debian using TVheadend with the latest crazycat's drivers.
I can offer SSH access to help with it.
Thanks.
Newtman
Re: A lot of problems with TBS6522 and DVB-C
Postby smile » Mon Jan 02, 2017 3:45 pm
Hi newtman,
if you using the dvb_annex_b signal,you need changed mode to QAMB mode.
and if you test in the linux, your signal symbol rate must standard(QAM64 : 5057 QAM256: 5361),because it do not delivery symbol rate to driver.
Best Regards
smile
Postby Newtman » Wed Jan 04, 2017 10:19 am
smile Wrote:Hi newtman,
Best Regards
I config QAM256 and SR 5360 before buy the TBS 6522 because I´m still using my old TBS 6221. The exactly config with TBS 6221 work but not with 6522.
I checked with scan-s2 and it found muxes and channles... I don´t understand. :?
Newtman
Postby Newtman » Fri Jan 27, 2017 12:21 am
Now I'm using without problem my TBS 6522 with crazycat's driver! :D Debian and kernel 4.9
But in Windows DVB-C is still broken...
Newtman
