Linux kernel updates: automatically reinstall driver
Postby petwri » Sat Nov 05, 2016 7:38 pm
I have been using the official drivers for my 6928SE for quite a while. Compiling an installing worked fine on my linux 4.4.0. But the problem is, that since it's a manual kernel module installation, the module always vanishes after a kernel upgrade. I tried using dkms and writing a dkms.conf, but no luck. Also been looking out for a deb-pkg, but I haven't found anything.
Is there an "official" way how to deal with linux-tbs-drivers using dkms, or maybe some official support?
Thanks!
petwri
Re: Linux kernel updates: automatically reinstall driver
Postby crazycat » Sat Nov 05, 2016 8:04 pm
Dkms packages always unofficial :D
Postby petwri » Sat Nov 05, 2016 10:20 pm
Can I find a working dkms.conf for linux-tbs-drivers somewhere?
petwri
Postby crazycat » Sun Nov 06, 2016 8:13 am
ask some google :)
Postby petwri » Mon Nov 07, 2016 4:48 pm
crazycat Wrote:ask some google :)
You got a PM.
petwri
Postby Ericed1965 » Thu Aug 31, 2017 1:42 pm
I have the sam e issue. Did you find a solution?
Ericed1965
