FAQ about TBS tuner card
Postby steven » Wed Jun 29, 2016 4:57 pm
Hi all
Some FAQ about TBS tuner card please have a check.
Linux:
1.How to install the driver
Please have a look at this guide:
viewtopic.php?f=86&t=9875
2.Can not compile the driver in CentOS 7
check your kernel version:
uname -a
Link the build folder .Go to this folder such as :
cd /lib/modules/3.10.0-327.13.1.el7.x86_64/
ln -sf /usr/src/kernels/3.10.0-327.10.1.el7.x86_64/ build
Then install the driver as normal steps
3.How to use tvheadend.
Here is the video:
https://www.youtube.com/watch?v=f5-b1w-4v_A
4.How to use astra.
https://cesbo.com/en/astra/quick-start/
https://cesbo.com/en/astra/docs/
5.How to use OSCAM
viewtopic.php?f=165&t=9482
6.How to use mumudvb
http://mumudvb.net/documentation/asciid ... START.html
http://mumudvb.net/documentation/asciid ... _CONF.html
Windows:
1.Is your driver support windows 10
No problem you can feel free using windows xp,vista/7/8/10
2.Can not watch the HD channels,only picture or only audio
Make sure that you have install the right video and audio decoder
3.where i can get the TSReader dll support
You can get it on our download page :
http://www.tbsdtv.com/download/document ... 150604.zip
4.where i can get the StreamReader dll support
http://www.tbsdtv.com/download/document ... .0.0.3.zip
5.Why can not use it with Windows Server 2008
Please install this patch for your windows server 2008:
http://www.tbsdtv.com/download/document ... 08_bda.zip
6.The card don't been detected by motherboard
please refer to attached pics to change some pcie setting on BIOS and update the BIOS to the latest version. make sure set the PCI-E link speed to Gen1 like this ,as most users after set the BIOS it can detect our card so you can have a try.
7.How to set dvbdream support 8 diseqc.
Open “Options” item then select “Diseqc”, Diseqc Switch Type “None ”
After add one satellite, open “Properties”, can set diseqc port by “Uncommitted” from 0 to 15
8. What kind of antenna to use(DVBT/DVBT2 Card)
Our all dvbt/t2 card just support the parasitic antenna. If you use the active antenna, you need supply power to antenna.
9. Whether support CI+.
Our all CI card just support the CI, do no support CI+.
Return to News
Users browsing this forum: No registered users and 18 guests
