How to install open source linux driver
Postby steven » Sun Sep 30, 2018 10:36 am
Hi All
As we already released our open source driver the driver install way is little different with before ,please check these steps to intall :
1.Go to our Github page you will find detail information :
Downloading and building
cd media_build
make dir DIR=../media
make allyesconfig
make -j4
sudo make install
sudo reboot
Firmware
wget http://www.tbsdtv.com/download/document/linux/tbs-tuner-firmwares_v1.0.tar.bz2
sudo tar jxvf tbs-tuner-firmwares_v1.0.tar.bz2 -C /lib/firmware/
2.You can try our offline open source package usually after some time we will prepare one package .
#wget http://www.tbsdtv.com/download/document/linux/media_build-2020-01-02.tar.bz2
#tar jxvf media_build-2020-01-02.tar.bz2
#cd media_build
#./install.sh
#reboot
Some FAQ :
/bin/sh: 1: lsdiff: not found
sudo apt-get install patchutils
you may need to install the Proc::ProcessTable module
sudo apt-get install libproc-processtable-perl
fatal error: drx39xyj/drx39xxj.h: No such file or directory
mkdir -p v4l/drx39xyj
cp v4l/drx39xxj.h v4l/drx39xyj/
Can not find the 6909 firmware
wget http://www.tbsdtv.com/download/document/linux/dvb-fe-mxl5xx.fw
cp dvb-fe-mxl5xx.fw /lib/firmware/
If you find module load errors like "module has wrong symbol version", this means that there still are old modules from your previous Media Tree installation (usually duplicated modules in two different places).
sudo rm -rf /lib/modules/``uname -r``/kernel/drivers/media/*
Cannot use CONFIG_CC_STACKPROTECTOR_STRONG: -fstack-protector-strong not supported by compiler
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt-get update
sudo apt-get install gcc-4.9 g++-4.9
sudo rm /usr/bin/gcc
sudo ln -s /usr/bin/gcc-4.9 /usr/bin/gcc
make[2]: gcc: Command not found
For CentOS 7 Please check this steps
Update to new kernel
#rpm --import https://www.elrepo.org/RPM-GPG-KEY-elrepo.org
#rpm -Uvh http://www.elrepo.org/elrepo-release-7.0-2.el7.elrepo.noarch.rpm
#yum --enablerepo=elrepo-kernel install kernel-lt-devel kernel-lt -y
#grub2-set-default 0
Restart to load the new kernel and install gcc unzip
#yum -y install gcc
#yum -y install unzip
#reboot
Install required libraries
#yum -y install perl-devel perl-ExtUtils-CBuilder perl-ExtUtils-MakeMaker
#yum -y install patchutils
Install the SHA
#wget https://sourceforge.net/projects/moiproamd/files/Files/Digest-SHA-5.93.tar.gz/download-O Digest-SHA-5.93.tar.gz
#tar xvf Digest-SHA-5.93.tar.gz
#cd Digest-SHA-5.93
#perl Makefile.PL
#make && make install
Install Perl
#wget https://sourceforge.net/projects/moiproamd/files/Files/perl-proc-processtable-master.zip/download -O perl-proc-processtable-master.zip
#unzip perl-proc-processtable-master.zip
#cd perl-proc-processtable-master
#perl Makefile.PL
Start install the open source driver, then start install the driver.
Re: How to install open source linux driver
Postby steven » Fri Feb 08, 2019 5:28 pm
We find that sometimes when using ubuntu kernel 4.4.0 can not install the driver , compile and install both are ok
but there is no dvb device in this case please update the kernel to 4.16 then try again
update the kernel you can do like this :
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.16/linux-headers-4.16.0-041600_4.16.0-041600.201804012230_all.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.16/linux-headers-4.16.0-041600-generic_4.16.0-041600.201804012230_amd64.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.16/linux-image-4.16.0-041600-generic_4.16.0-041600.201804012230_amd64.deb
sudo dpkg -i *.deb
reboot
after reboot using
uname -a check the kernel weather is 4.16 is yes then start install like this :
#wget http://www.tbsdtv.com/download/document/linux/media_build-2019-0308.tar.bz2
#tar jxvf media_build-2019-0308.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby steven » Tue Jun 01, 2021 2:47 pm
Hi All
some customers follow the github steps still can not install the drivers then you can try with offline package
please have a try with this package :
# wget http://www.tbsdtv.com/download/document/linux/media_build-2021-05-08.tar.bz2
#tar jxvf media_build-2021-05-08.tar.bz2
#cd media_build
#./install.sh
#reboot
thanks
Return to News
