Weak reciever other ok
Postby desauld » Sun Mar 30, 2014 2:50 am
So my 5280 will scan and pick up 83 channels on reciever a but reciever b only picks up 27 channels. I'm using Mediaportal but have the same problem with the supplied software. The machine is a amd a10 6700 with 16gb ram and a ssd. I also run a tbs 6281 in the same machine and another t2 usb reciever all working OK apart from this issue. What ccould be wrong?
Thanks des
desauld
Re: Weak reciever other ok
Postby desauld » Wed Apr 02, 2014 2:10 pm
Can't anyone help with this? Looks like a hardware issue? Or is there a better driver version to test?
desauld
Postby desauld » Fri May 30, 2014 7:38 pm
So Tbs doesn't care about its faulty products?
desauld
